Question about Amana Washing Machines
Have Amana Top Load Washer - Model NTW4650YQO - about 6 months after purchase, warm water wash switch/setting is not producing "warm" water like it did before. I understand about the hot & cold mixing that's is regulated by thermo sensors because of energy saving features. On first service call, tech replaced water inlet valves P/N 10423125. Did not correct problem. Tech said that main control board plus temp switch setting will be now replaced. Waiting for parts. What's the next step if problem isn't corrected?
SOURCE: Kenmore washer "warm" wash cycle not above room temperature
aaa
Posted on Jul 09, 2009
suben
  • 214 Answers
SOURCE: My Maytag washer is overflowing
the inlet valve has to be checked or replaced if required
Posted on Sep 09, 2008
Maytag317
  • 1136 Answers
SOURCE: Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Posted on Jul 01, 2009
elisa_ashley
SOURCE: I have a kenmore elite H3 washer. The cold water
Check the inlet valve solenoid wires for resistance with an ohms meter. The cold and hot solenoids should have close to the same resistance. My washer had a weak solenoid causing the hot water valve to close after 4 or 5 seconds. While checking the solenoid wires for resistance with the ohms meter, I noticed the cold side had 51 ohms but the hot side only 8 ohms. Hope this helps.
Posted on Sep 21, 2012
SOURCE: water temp
Good Morning, Pull the hoses off of the washer again, noting which hose goes where. You may have to pull the washer out to see this. Look at the male parts that are exposed. Take something sharp and pull filter screens out and clean. Reinsert and install hoses. Did it fix it? If not, you need a new water valve part number; 3979346 $35.92 at Sears. Hope this helps and have a good day
Posted on Nov 27, 2012
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin ยท Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Amana Washing Machines
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Pump is not starting to pump water out of whirlpool ultimate 2
I suggest you purchase a lid switch from a local supplier of parts or call a local servie tech if it's just the lid switch it should not take a tech long to change it.
Dec 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana Top Load Washer model# LW3502W Washer leaks water somewhere between wash & rinse cycle best I can tell...drain hose checks out fine. At beginning of wash cycle the first minute or two of agitation...
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Oct 30, 2007 | Amana ALW480DA Top Load Washer
Washing Machines Logo
126 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
