Question about Electrical Supplies
I have a 15000 watt generac generator and in the past this unit burned up a circuit board and it was replaced. she ran good it sat up for 4months and now she wont crank. I cleaned out the carb replaced the fuel. the fuel pump works so eney way the fuel solenoid does not work on the switch I jumped the solenoid and still wont crank it will run for only 2 seconds. I replaced the spark plugs and I notice that one of the plugs seems to have a lot fire than the other one almost to much does that make since? maybe I have an electric problem like a stator issue???.
  • logic pro
    logic pro Oct 11, 2013
    oh! i forgot to tell you that i cleaned the carb threw anout and replaced the fuel as well,thanks
    Prodigy:
    An expert who has answered 500 questions.
  • 573 Answers
No it isn't a stator issue a complete check of the ignition and control needs looking at.
Posted on Nov 17, 2013
3 Suggested Answers
joboo1
  • 257 Answers
SOURCE: cranks fast but wont start
Hi, You did a good job of diagnosing your problem. Gas in bowl and dry plugs, starts with fluid, But, to quote you, "won't go through carb" . If you feel confident, you should disassemble and clean the carb, as that is going to be the problem. As a tip, if the genset is going to sit make sure to turn off the fuel flow to the engine and run till the engine dies. They do not like to sit any length of time with fuel in the carb. Good Luck, this should Fixya!
Posted on Mar 02, 2009
SOURCE: I have a Generac 15000 watt portable generator. It
I have solved the flooding problem . unfortanetly you must remove the carb to fix it. once you remove the carb you need to remove the fuel bowl. In the bottem of the fuel bowl there is a electronic seloniod that controols the amount of fule going to combustion. this aria had varnish and gunk built up around the plunger of the selonoid, long story short clean this out with carb and chook cleaner and put it back together. start her up and she will run like a champ.
Posted on Apr 27, 2009
When i start the generac 15000 it starts fine but once a load is put on it it will die aS SOON AS THE LOAD STARTS IT JUST QUITS
Check the governor and throttle for easy movement. When the load increases, the governor should advance the throttle to keep the speed up.
May 07, 2015 | Generac 15000 Watt Portable Generator w/...
How do i remove the camshaft from generac 15 k generator
I would do a compression test before you removed a cam.
How did you diagnose the camshaft?
Sep 11, 2014 | Generac Generator 15000 Watt 15kw
Generac 15000 watt generator blows 15 amp fuse when it try to exercise
a weak battery will cause the 15 amp system fuse to blow, even though the battery can still actually start the generator.
Nov 29, 2013 | Generac Electrical Supplies
Cranks then dies
yes this unit will run for only a second or two then dies. the fuel pump is pumping well
Apr 24, 2012 | Generac Power Systems Generac 5734 15000...
I need a wiring diagram for a generac gp15000e generator
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
Nov 05, 2011 | Generac Guardian Ultra Source 15,000 Watt...
Guardian 15000 Watt Portable Generator will not charge the 12volt battery. Help
Suggest you go to Amazon.com and do a search for the Generac Guardian. When you find it, look in the product details and you will see Product Manual (PDF) under the Product Details.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000031765.pdf
it has a troubleshooting guide located on page 19.
No Battery Charge DC output.
1. Battery posts are corroded. 1. Clean battery posts.
2. Battery cable is bad. 2. Replace cable.
3. Battery is defective. 3. Check battery condition; replace if
defective.
4. Receptacle is bad. 4. Contact Authorized Service Facility.
Hope this helps!
Jun 02, 2011 | Generac Guardian Ultra Source 15,000 Watt...
Dont have 12 volts to start switch generac guardian ultra source
Have you checked the fuse? Mine keeps blowing the fuse (located on the back of the control panel) with each startup and shutdown or use of idle control.
Jun 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
My Guardian 16KW
I have never heard that generators need to be perfectly level to prevent generator damage. It doesn't compute -- auto generators/alternators run at all sorts of angles -- so do motors. And for the damage to occur in 2 hours running doesn't sound right either.
It does sound like the generator itself is not working/generating properly, but I doubt it was caused by the slab.
Apr 29, 2009 | Generac Guardian Quietsource 25,000 Watt...
Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
94 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
