Question about Casio Parts Cash Register PC Desktop
Printer does not advance across register taps just moves about 1/8" then stops and prints all in that spot
    New Friend:
  • 156 Answers
You will need to open the register up and check for a paper blockage or dirt and clean it ... then try again.... also wouldn't hurt to check the settings to make sure its not setup by default to do that... or might even be a paper with setting that needs adjusted
Posted on Oct 15, 2013
I HAVE A HP ALL IN ONE D110 PRINTER IT MAKES A LOUD TAPPING NOISE WHAT IS IT'S PROBLEM AND CAN IT BE FIXED AND HOW?
Depends on where the tapping is coming from. If it is the print engine then the encoder strip might be dirty and stopping the printer from being able to track where the head is. Open the front door and look for a clear strip that runs across the printer, it is located in the area where the printhead moves back and forth. It has a micro grid printed on it that an optical eye tracks to see where the head is located. If dirty it can be gently cleaned with a soft cloth dampened with water. Use caution because if you scratch it, you may render the printer unusuable.
Oct 06, 2015 | HP Office Equipment & Supplies
Www ecasiorepair com
A motor is used to move it back and forth which is sometimes attached to a belt ... maybe the belt fell off the motor...?
Oct 11, 2013 | Casio Parts Cash Register PC Desktop
Hi: Re HP Photosmart D5160 printer: 1) Prints a
You may have added a separator page,
1). Open printers and Faxed.
2). Right-click your printer and select 'Properties'.
3). Click 'Advanced' tab
4). click 'Separator Page'
Delete any text in the box and click 'OK'
Sep 13, 2011 | HP Photosmart D5160 InkJet Printer
Canon Multipass F30 not printing
Did you remove the tab that covers the cartridge head where the ink comes out, if the drivers and software that you loaded on your pc work
good and your printer shows under device MGR, then it is the printer
itself,,most times you can not see how much ink in the cart,,,most are sealed,,,just try to put the cart in again and make sure it is locked in good,,try running the cleaning program with pc,,make sure the right
cart is in the right spot, bl in one spot and color in a spot.
Dec 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Photo paper stops feeding
please verify that the main roller that is moving the paper out while its being printed upon is moving....if its not or it moves a bit verify that the gear teething are all intact at the gear assembly end....
check to see that you don't have worn out rollers.
Nov 02, 2008 | HP PSC 750 All-In-One InkJet Printer
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
MFC-3240C
The printer may not be scratching your printout but you may have a clogged printhead. A clogged printhead will constantly miss a spot creating an effect of a scratch printout. Please run an all inks printhead cleaning routine (2 or 3 times) and create a test page. Best Regards
Aug 20, 2007 | Brother MFC-3240C All-In-One InkJet...
Deskjet HP 6940
this might be a software problem also. please specify which software you are using to print these banners. Thanks
Jun 12, 2007 | HP Deskjet 6940dt InkJet Photo Printer
Casio Parts Cash Register PC Desktop Logo
32 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
