Question about Frigidaire Affinity ATF7000E Front Load Washer
The dryer door won't open its been 2 months when we stop using it, when we moved to apartment, since we can't use it here i am planning to sell it, but when i tried to open the door it won't open. even i plugged it in,....do we need to hook it in the gas to open it.?
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon maricris, thank you for your inquiry!
If your door is in the locked position, first reset the power to the unit for about one minute. Can you open the door? If so, the main control board may need replacing. If you cannot open the door, then the door switch assembly may need to be replaced. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Posted on Oct 14, 2013
2 Suggested Answers
  • 1531 Answers
SOURCE: We have a frigidaire front
The first thing to check is your water supply lines and make sure there is no sediment build up.You may need to replace the main control board,also check to make sure the drain pump is not block or restricted.
make sure you have the proper voltage to the machine.
Posted on Sep 07, 2010
Have a broken door switch. will that stop the dryer from heating?
A broken door switch does one of two things, either the machine will not start, or when you open the door the machine will not stop tumbling. Heating issues are caused by improper voltage, bad heating element, burned wires, faulty thermostats etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Aug 12, 2013 | Maytag Dryers
Rgx4634kq2
make sure push start switch is not stuck pushed in.Also sounds like the switch mounted on the motor could be stuck, which means new motor. Does motor start and stop with timer being moved to the off position ?.If so then not the motor.
Jul 01, 2013 | Dryers
Pye2200ay won start
Is the plastic locater lug on the door that makes contact with the switch... intact and making breaking the switch properly?
Also check the switch mechanism to see if it is functioning correctly
This could be your problem if you say everything works ok. when you part the wires of the switch.
you may need to replace one or the other or both if you can remove the door switch take it to a shop that sells parts and ask them to confirm it is working.
You could also ask if you could see a plastic lug off the door then you will know if that could be faulty also?
Best of luck!
Jun 15, 2013 | Maytag PYE2300AY Electric Dryer
After moving dryer to new apartment, worked at first but now won't turn on
Did you check the power source? You could have popped a breaker (or fuse) if the dryer circuit in the new apartment is inadequate. Might have been good for one shot, then no more.
Sep 03, 2012 | Maytag Dryers
Dryer won't start
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My Maytag Neptune electric Dryer will not stop unless it is unplugged or door is opened.
check the door switch,when you open the door the dryer shouls stop,push in on the door switch and let it out,it should click when it pops out,if the switch broke pushed in it won't shut off.the part number is W10169313 and it's around 16 dollars,
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
Dryer
#1 Unplug the dryer
#2 Use a putty blade under the corners of the Console and flip it back
#3 Remove 3 screws along back of top that were under the console (Might just be 2)
#4 Slide the top forward and remove
You will now have full access to the switch. Disconnect the harness and replace the switch.
#5 Reverse the above proceedure to replace the top
Good Luck,
Eric
Jun 08, 2009 | Kenmore 64902 Electric Dryer
Buzzer won't go off when dryer is stopped - All else works fine - must leave door open
Fiddled around with the start button. It had gotten stuck in the on position and when I moved it around it freed up. I consider this a temporary fix only and have already ordered a replacement switch.
Aug 02, 2008 | Maytag Dryers
Frigidaire Affinity ATF7000E Front Load Washer Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
