Question about Kitchen Ranges
I need to some natural gas jets to put into a 900DFA
    Problem Solver:
  • 17 Answers
Go to your local fixastove place
Posted on Oct 11, 2013
Maytag range Natural gas jets to Propane jets
it is a simple replacement but the problem is properly adjusting the air shrouds to get the right air/ gas mixture to burn correctly
lpg jets are available from a gas supply shop and because of the dangerous nature of gas , I would suggest that you have an accredited gas fitter do the conversion
Nov 25, 2015 | Maytag MGR8674AS
Can I convert a 450rb from propane to natural gas
The simple answer is yes. However you will need to convert it. Simple process for a gas fitter, they will put a natural gas regulator on and possibly change the jets. Natural gas runs at a higher pressure than Propane. What ever you do, do not run without conversion, it will fail with possible fire or explosion.
Oct 04, 2015 | Kitchen Ranges
Hello Everyone, I have a Totum Patio heather the Natural Gas models. I now have to move to a condo with no natural gas access. Can I convert this Natural Gas model with the LPG models that uses Liquid...
It can be done but you will need a professional gas fitter to do the job. It will need different jet sizing and the air mixture tube adjusted to compensate for the different jets.
Oct 27, 2013 | Barbeques Galore Totum Hls 35,000 Btu...
Rangemaster 110 on lpg wish to convert to natural gas
You must get a tradesman or technician who is qualified to convert a gas appliance, your local gas fitter or plumber should be able to help with this. the regulator needs to be changed the jets also need to be swapped out for the type of gas to be used. normally from lpg to Natural gas the jet size needs to be increased by installing new jets or by drilling out the old ones
Hope that helped
Oct 22, 2013 | Rangemaster 110 (Gas) Kitchen Range
I need to change the stove to operate on propane instead of natural gas.
You will need to conact a gas safe engineer who will change your gas jets from natural gas to LPG, then carry out various test to makesure your flueless appliance burns the gas safely and efficiently
Jul 11, 2011 | Hotpoint Kitchen Ranges
Just put in a new Caldera LPGas cooktop the flame is yellow and putting soot on pots how can I adjust air to correct this?
you stove may have jets for natural gas rather than bottled gas the calorific value of natural gas is different to propane and the jets are larger because of this. if using bottled gas then you will get yellow flame and soot because there is too much gas to burn properly check your installation manual for procedure to change the jets for each gas
Dec 19, 2010 | Stainless Caldera SSK-305 Steel Gas...
3E461LP coversion
you need to find the gas jet that feeds the burner, the jet has to be changed to natural gas, which is a bigger jet. some of them can't be changed because the jet is part of the gas line
Jan 31, 2010 | Dayton (3E461) InfraRed Heater
I want to switch my 5 burner kleenmaid CH80x8 natural gas cooking top over to LPG what size jets or injectors do I need. Regards James. Centre burner is for a wok current jets are 50. 78. 85. 62. 95
LPG to natural, natural is bigger than LPG injector exmaple LPG 50=natural 69-
LPG 78=natural 91
LPG 85=natural 115
LPG95=natural 130
PLG 62=natural 85
Sep 09, 2009 | Cooktops
Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
I want to convert to natural gas.
The only thing you can do if Weber doesn't have a natural gas manifold for their grills , is to buy one that will fit. They use propane on outside grills because of the stability of the gas. Natural gas will blow out much easier.
Feb 25, 2009 | Weber Genesis Silver B Grill
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
