Question about TP-LINK TD-W8901G Router
Authentication error occurred - TP-LINK TD-W8901G Router
Outlook: None of the authentication methods supported by this client are supported by your server
For more information about repairing or configuring your Outlook email account, click the following link:
https://www.pstrepairkit.com/
Regards,
Arnold Warner
Oct 17, 2016 | Computers & Internet
Error occurred (-42408).
Symptoms: If your iTunes is missing resources or encountering software conflicts, error -42404 or -42408 may appear when authenticating or downloading from the iTunes Store. Resolution: Update to the latest version of iTunes.
Apr 08, 2013 | Apple MacBook Air
"Packet Data Authentication Failed" what is
The error msg "packet data authentication failed" is displayed when connecting to internet via cell phone, even after having the original configuration settings provided by the supplier set to default. The problem can be solved by the following method or else contact the service provider. >Delete the old settings and then by switch off the phone. >Remove the sim card and reinsert it, after some time >gett the new settings and set it to default. Hope this helps. I had the same prblem. Even after calling cc, nothing helped. I tried all things but failed. Then unfortunately, i entered the url of the sp in the access point setting manually and wow it worked. I did this by using uninor.
Jun 17, 2011 | Nokia 2626 Mobile Phone
Hi my name is pandi.c i configure the mai id but smtp authentication error is occured any pls help me
Hi pandi ci smtp autthentication error occurs if the email id or password you configured is wrong or the smtpserver did not respond. the authentic email id should have the same extn as the smtp server
for example:
if your smtp server is smtp.gmail.com ten the authenticating email id should be xxxx@gmail.com.
the error also comes if the smtp authentication has been enabled. you can disable it and send docs without authtion . contact you sys admin . ok hope this helps u . bye
Narasimha kumar (INDIA)
Jan 19, 2011 | Canon iR 2016i Black and White Copier
Unable to obtain authentication input/output error has occured.\r\nno sacanners found
unable to obtain authentication input/output error has occured.module is not register
Dec 14, 2010 | DigitalPersona U.are.U 4000 Fingerprint...
Unable to obtain authentication input/output. unable to obtain authentication input/output error has occured. error while loading applet module is not registered
if u r using your scanner on jamb website. You will need a biometric license and offline software. We have several license in stock to give away. While not call us today, if the problem is still persisting. Call 08132829820
Dec 01, 2010 | DigitalPersona U.are.U 4000 Fingerprint...
Unable to obtain authentication input/output error has occured. error while loading applet module is not registered
Nov 19, 2010 | DigitalPersona U.are.U 4000 Fingerprint...
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | Computers & Internet
TP-LINK TD-W8901G Router Logo
Top TP-LINK Computers & Internet Experts
Martin Murray
John Anderson
John Anderson
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
