Question about LG VERIZON VX5200 Hands-Free Headset (Silver) 98323 / AAYN4264A / 22802H Headset
Cell Phone Issue
My phone got wet for getting rained on, and now I cannot get it off of Car Kit I cannot hear people or be heard. I was looking a solution but I cannot find that info on my phone. I have a vx5200 LG cellular phone.
Take a piece of metal like a bobby pin and rub it on the bottom of the phone where you plug the charger in. This will reset the phone. It work for me and saved me from buying a new phone.
Good luck!!!!!!!!!
Posted on Mar 17, 2008
Cant hear or be heard
Dear S quart. think that the problem is in the hardware, not in the software, that's why i think that you shouldn't ask that question in here, because you need a cell phone repair. Usually, that problem come from liquid inside the phone, may be your phone get wet bye the rain or fall in something wet, or, it became so old. But sometimes, you can easely fixe bye doing one unexpected thing, Changing the cage of your cell phone? I have my self a Nokia 3110c, it was hard to hear others when they call me or when do call them, but when i change the cage, i found some dust behind it, and the voice is more clear now and even higher.
Jun 19, 2011 | LG enV3 VX9200 Cell Phone
My LG Voyager seems to be stuck in car kit mode, it did not get wet, (I read alll the blogs on getting wet is cause and the verzion rep said thats what it was, however, it didnt get wet, I copmpared the...
I just had this same problem. It is a hardware issue. Call verizon back explain the situation, they will call your phone to verify that the mic and speaker aren't working and they will send you a replacement within 2 days.
A temporary solution is plugging a wired headset into the phone and taking it out, it will work for a few hours.
Sep 04, 2009 | LG VOYAGER VX10000 Cellular Phone
Walkman gets heated for less time,frequently not responding to in and outgoing calls
Has the phone gotten wet at all? Anything at all - using it in the rain, having it in the bathroom whilst having a bath or shower, anything like that?
Sounds like something physical has gone wrong somewhere! If it's still under warranty see if you can get it repaired/replaced under warranty.
May 23, 2009 | Sony Ericsson w580i Cellular Phone
LG Phone has Car Kit Error. Didn't Get Wet. Can I Clear it
Dear customer,
                     To Remove “Car-kit” error there are few ways:               What worked for me as suggested by chemist  is using Calcium Chloride (CaCL2) as a drying agent since it pulls moisture out of the air, and according to Verizon, this car-kit error is caused by exposure to moisture. For the average person, you can find this in the form of “Prestone Driveway Heat Concentrated Ice Melter” (or other ice melter – check ingredients).
1) Pour about 1 cup or so of CaCL2 in a small Tupperware container.
2) Place a sheet of paper on top of the CaCL2 to protect the phone.
3) Place the phone on top of the paper so as not to allow phone to touch CaCL2 (this is important).
4) Place the lid tightly on the Tupperware container.
5) Allow to sit overnight.
In the morning, the “car-kit” error was gone! Yay! I could could hear my callers, they could hear me, and I could hear all my ringers.
                         Other suggestions that  might work for you are.
         Car Kit
 To remove errors from phone:
#1) press soft key for menu
#2) then press 0
#3) you'll have a service code prompt, type 000000
#4) then type 2 (it should be field tests)
#5) then type 4 (clear errors)
#6) choose yes for clear errors
#7) press clear once
# type 8 (FCC test)
#9) type one (pcs)
#10) type one again (set channel) (mine shows 426 I don't know if theres a different channel for each phone.)
#11) press clear 3 times and the phone will reset.
                       FOR RESTTING
Enter "Menu"
Select "Settings"
Select "Security"
Enter "Lock Code" - Will default to last 4 digits of phone number or "0000" unless changed.
Select "Reset Defaults"
Press "Ok"
Plz rate this solution.. thank you..
Apr 09, 2009 | LG VX8300 Cellular Phone
Car kit
you somehow got it wet. bring it to your provider and they'll tell you the same.
Oct 26, 2008 | LG VX8300 Cellular Phone
Getting an error that says car kit on phone
Mine said car kit and I kept reading it was because it got wet, and my phone didn't get wet. I noticed a little corrosion where I plug the phone in starting to form and I rubbed a little off and the car kit on the main screen went away.
Sep 08, 2008 | LG Cell Phones
I can't hear you !!!!
Car Kit doesn't necessarily mean the phone got wet, but it does mean that there's a problem with the charging port. Most likely there's a lot of corrosion in there, and if you clean it out then it may get the phone working again.
The best way to clean your charge port is with some contact cleaner and a toothbrush.
If the problem persists after that, then you'll want to bring it in to a store and get the phone serviced or replaced.
Apr 27, 2008 | LG VX8300 Cellular Phone
Car kit mode
it could be a liquid damage if not u need to refurbish the phone by downloading the operating system
Feb 29, 2008 | LG VX8300 Cellular Phone
Car kit
there is no setting to find. clean charger port with rubbing alcohol and a tooth brush, be gentle. turn off - let dry and recharge for 2 hrs. worked for me. pain I know. taking battery out will not help. but should check battery conections to see if they are clean,do the same as above. if purple you have water damage. verizon warranty is void if this is the case.
Aug 06, 2007 | LG VX8300 Cellular Phone
"Car Kit"
this model do that when it get wet if that the case there is nothing to do but chage the board, go to the celu store they have jonk to fix these for about $25.00 more or less..good luck
Aug 06, 2006 | LG VX6000
Radio Communications Logo
79 people viewed this question
Top LG Radio Communications Experts
TO Lady
Mohamed Ismail
Mohamed Ismail
Computer Repairing
Computer Repairing
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
