Question about Casio Parts Cash Register PC Desktop
Www ecasiorepair com
Printer is not advancing just prints everything i ome spot does not move accross paper
    New Friend:
  • 156 Answers
A motor is used to move it back and forth which is sometimes attached to a belt ... maybe the belt fell off the motor...?
Posted on Oct 15, 2013
Paper jam after fuser replacement.
Since you reset the counter you reset your paper size .the paper detection flag ,spring that returns it to its h ome position knocked off. Check all your connectors and make sure the drive gears are meeting up. Most fusers have what they call a pivot gear. It has a spring that engages it to the main drive . Make sure there meeting up. Tip ,mark a gear and make sure it rotates. White out works well to mark a gear. You could have a bad part.
Aug 18, 2015 | Brother MFC-9330CDW - Led Multifunction...
4200 PRINTER Only wants to print out of tray 1
First you need to verify that tray 2 will print from diagnostics test. Use the arrow keys to scroll down to diagnostics and press arrow key, then use arrows move to paper path test and press arrow again. The default paper path test is tray 2 single copy so just select print paper path test and see what happens. If printer prints from tray 2 then we know tray 2 works and that means you either have a print driver that is forcing printing from tray 1 or your settings on the printer for tray 2 are not correct for what you are printing. Check to make sure the paper size shows correctly and make sure that the switch on the right side of the paper tray towards the back is set for standard and not custom.
Aug 04, 2014 | HP LaserJet 4200 Printer
Black spots at the back page
Hi George,
Sounds like you are on the right track.
The spots on the paper you describe on the back of the paper appear to be toner, and because they are on the back of the paper and you can rub them off, appears to be after the fuser.
To clean the printer, a vacuum cleaner will do a partial clean. You need to clean all the paper feed rollers.
Start by wiping the inside of the printer area with a soft, lint-free cloth to remove any dust, paper particles or spilled toner.
Then use a damp soft, lint-free cloth with clean water. Hold the cloth against each roller while rotating the roller. Keep cleaning the cloth. Do this for each roller inside the printer.
Read more: http://www.ehow.com/how_6913741_clean-roller-blades-samsung-clp_300.html#ixzz2sGMAltnZ
Feb 03, 2014 | Samsung CLP 315 Laser Printer
I try to print and the paper won't advance, prints everything on one line.
The unit needs to be cleaned and vaccuumed, pay carefull attention to the paper feed rollers. You might consider getting a Service Manual for it, if you do here is a link.
http://www.techmanualarchives.com/microline-320_321--turbo-service-amp-parts-manual-25647.html
Good luck.
Mar 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Error 6400 ink cartridges wont track accross
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Feb 07, 2010 | Office Equipment & Supplies
Specks on print out of Mono Laser Printer HL2040
If its spots this could have been from the cartridge or the fusser unit...
Do a half print test...send a print page to your printer listen to the printer print as soon as you think the printer has printed some little bit switch off the printer...take the cartridge and view the printed portion can you see the spots..if not.....than its your fusser unit thats marking the paper....remove the half printed paper slowly.....not to tear it......remover the fusser unit(hot unit)........at the back of the printer....towards the top....on the unit it self you will see a Teflon paper ....move the gear on the far end of the fusser unit itself and view if there is any spots....try cleaning this spots slowly as not to damage the Teflon or mark the Teflon.....
Nov 04, 2008 | Brother HL-2040 Laser Printer
Photo paper stops feeding
please verify that the main roller that is moving the paper out while its being printed upon is moving....if its not or it moves a bit verify that the gear teething are all intact at the gear assembly end....
check to see that you don't have worn out rollers.
Nov 02, 2008 | HP PSC 750 All-In-One InkJet Printer
Paper feed and printing problem
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others, it seems to reset the sensors or something.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through!! and hey presto it worked for me, everything printing fine now.
hope it works, let me know, Garty
Apr 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Saying no paper,. even when it's fully loaded & wont print.
i just thought i had the same problem... but you know how there are 2 buttons on the front of the printer once the paper output tray is down? the bottom of those 2 i think switches it back and forth between paper feeding from the normal, top spot, and from somewhere else, so you can try pushing that button! worked for me!
Oct 11, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
MFC-3240C
The printer may not be scratching your printout but you may have a clogged printhead. A clogged printhead will constantly miss a spot creating an effect of a scratch printout. Please run an all inks printhead cleaning routine (2 or 3 times) and create a test page. Best Regards
Aug 20, 2007 | Brother MFC-3240C All-In-One InkJet...
Casio Parts Cash Register PC Desktop Logo
26 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
