Question about Miele W865 Front Load Washer
What voltage is a miele ws 5427 - Miele W865 Front Load Washer
Washing Machine 3 phase
NOPE! Unless you want to use it just that last time!
Jan 19, 2014 | Miele Washing Machines
Miele Vacuum(Saturn300). Vacuum powerhead(SEB234/236) does not work, no light comes on and no power. is it the hose(SES119) or the powerhead? tried plugging and unplugging.
You need to check your voltage coming out of your hose and wand, be sure that the handle switch is in the on position. Voltage should be +/-120V. If you have voltage there then you have a power head issue. The replacement would be the SEB 228, you could also use the SEB 236. The SEB 236 is a deluxe version of the SEB 228.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Feb 24, 2013 | Miele Vacuums
I'm looking for a service manual for Miele WS 5425 washing machine, any ideas where i can obtain one?
i have a Miele ws 5425. it wil not open even though though the cycle has finished. It still full of water. The red fault light flashes on the drain symbol.
Jun 17, 2010 | Miele Washing Machines
Miele vacuum powerhead
My power head failed due to the handle switch. It comes apart with the Phillips screw under the vacuum kill slider. Check for continuity across the switch contact solder points.
Mar 01, 2010 | Miele S251i Plus Bagged Canister Vacuum
Miele ws 5105
Single Phase
Feb 08, 2010 | Washing Machines
Miele WS5426 Heater Element Replacement
On the WS 5426 the elements are mounted at the bottom of the drum of the accessed by opening the front of the machine.
Removal of the elements will involve destroying the rubber seal and can be done by cutting two vertical slots with a sharp knife in the seal and then pulling hard on the seal with a pair of pliers. It is not necessary to remove the spring clamps or drip shield but it will aid access to the seal.
Mar 11, 2008 | Miele Washing Machines
Miele W865 Front Load Washer Logo
24 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
