Question about Electrical Supplies
Torque settings for er40 generator - Electrical Supplies
Zanussi electrolux zwf14581w won't start, displaying Er40
my father had a zanussi dishwasher that did the same thing, turns out one of the door sensors had gone and would not release the lock. had to get an engineer out, luckily it was under warranty.
Apr 05, 2012 | Washing Machines
Need to change alternator belt 2003 kia spectra
1. Remove AC and P'S drive belt, if equipped.
2. Loosen generator mounting bolt and adjusting bolt.
3. Remove generator belt.
4. Install new generator belt and adjust to specification.
5. Tighten all bolts to specified torque.
Tightening torque mounting bolt: 27-38 Lb-ft (37- 52 N.m. 3.8 -5.3 kg-m)
Adjusting bolt: 14 - 18 Lb-ft (19 -26 N.m. 1.9 -2.6 kg-m)
6. Install AC and P'S drive belt, if equipped. and adjust to specification.
Nov 28, 2011 | 2003 Kia Spectra
Alternator mounting diagram
1999-2005 To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • The negative battery cable
    • The windshield wiper system module cover (if equipped)
    • The fuel injector sight shield (if equipped)
  3. Rotate and secure the engine forward.
  4. Remove or disconnect the following:
    • The generator B+ lead
    • The generator electrical connector
    • The generator from the generator bracket and position the generator above the drive axle
    • The drive belt tensioner
    • The generator bracket
    • The power steering pipes from the power steering pipe retainer
    • The fuel pressure test port (schrader valve) cap from the fuel injector rail NOTE: Do not disconnect the power steering pipes from the power steering pump.
    • The power steering pump and reposition in front of the timing chain cover in order to provide access for the generator
    • The generator from the vehicle
To Install:
  1. Install or connect the following:
    • The generator to the vehicle into position above the drive axle
    • The power steering pump to the engine
    • The fuel pressure test port (schrader valve) cap to the fuel injector rail
    • The power steering pipes to the power steering pipe retainer (if removed)
    • The generator to the generator bracket and position the generator above the drive axle
    • The generator front bolt
      1. Torque to: 37 ft. lbs. (50 Nm)
    • The generator rear bolts
    • The drive belt
    • The generator B+ terminal nut
      1. Torque to: 115 inch lbs. (3 Nm)
  2. Position the engine rearward.
  3. Install or connect the following:
    • The engine mount strut bracket bolts
for removal to reposition the engine
Feb 15, 2011 | 2000 Pontiac Montana
Alternator replace
Removal & Installation
NOTE There is a trend among manufacturers today to refer to the source of belt-driven electrical power as a -generator-; however, by virtue of the method in which the -generator- produces electrical current the device is actually an -alternator-. The two terms may be used interchangeably.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    Negative battery cable Accessory drive belt Alternator upper mounting bolt Engine splash shield Radiator support access panel Rear alternator bracket from the engine Alternator mounting bolts Duct on the back of the alternator Electrical connectors Front alternator-to-A/C bracket Alternator
To install:
    Alternator Front alternator-to-A/C bracket. Torque the bolt to 37 ft. lbs. (50 Nm). Electrical connectors. Torque the battery connection nut to 115 inch lbs. (13 Nm). Duct on the back of the alternator Alternator mounting bolts. Torque the bolts to 37 ft. lbs. (50 Nm). Upper front bolt. Torque the bolt to 35 ft. lbs. (47 Nm). Rear bracket to the engine. Torque the bolt to 37 ft. lbs. (50 Nm). Radiator support access panel Engine splash shield Accessory drive belt Negative battery cable
  2. Refill the cooling system. 4 DeVille
  3. Before servicing the vehicle, refer to the Precautions Section.
  4. Drain the cooling system.
  5. Remove or disconnect the following:
    Negative battery cable Accessory drive belt Radiator Electrical connectors Alternator mounting bolts Alternator
To install:
    Alternator Alternator mounting bolts. Torque the bolts to 37 ft. lbs. (50 Nm). Electrical connectors. Torque the battery connection nut to 111 inch lbs. (12 Nm). Radiator Accessory drive belt Negative battery cable
Dec 30, 2010 | 2004 Cadillac Deville
How do you replace an alternator belt in a 2001 kia sephia
Welcome to FIxYa.com
Replacement
1. Remove AC and P'S drive belt, it equipped.
Thank you for using FixYa.com
Regards, Lee Davidian
Dec 21, 2010 | 2001 Kia Sephia
How do i change alternator belt 2003 kia spectra
Replacement
Dec 20, 2010 | 2003 Kia Spectra
Check engine light code tcc 740
A tcc 740 is a code for a torque converter clutch problem. This is either the torque converter itself or the control part of the TCC system. dodge's have an issue with transmissions of this generation and in most cases when the code 740 sets, the transmission will need to be replaced.-------
This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Mar 20, 2010 | 2000 Dodge Caravan
How to change alternator on 2005 Jeep Wrangler Unlimited?
Straight out of the repair manual:
REMOVAL
WARNING: DISCONNECT NEGATIVE CABLE FROM BATTERY BEFORE REMOVING BATTERY OUTPUT WIRE (B+ WIRE) FROM GENERATOR. FAILURE TO DO SO CAN RESULT IN INJURY OR DAMAGE TO
ELECTRICAL SYSTEM.
(1) Disconnect negative battery cable at battery.
(2) Remove generator drive belt. Refer to 7, Cooling System for procedure.
(3) Remove generator pivot and mounting bolts/nut (Fig. 2) , or (Fig. 3). Position generator for access to wire connectors.
(4) If equipped, unsnap plastic cover from B+ terminal.
(5) Remove B+ cable output terminal mounting
nut at rear of generator (Fig. 4), (Fig. 5), or (Fig. 6). Disconnect terminal from generator.
(6) Disconnect field wire connector at rear of generator by pushing on connector tab.
(7) Remove generator from vehicle.
INSTALLATION
(1) Position generator to engine and snap field
wire connector into rear of generator.
(2) Install B+ terminal to generator mounting
stud. Tighten mounting nut. Refer to Torque Specifications.
(3) If equipped, snap plastic cover to B+ terminal.
(4) Install generator mounting fasteners and
tighten. Refer to Torque Specifications.
CAUTION: Never force a belt over a pulley rim using a screwdriver. The synthetic fiber of the belt can be damaged.
Jul 05, 2009 | 2005 Jeep Wrangler
Electrical Supplies Logo
29 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
