Question about Refrigerators
Not cooling fan on bottom on turning on not getting cold
Can frezzon be put in a hts17gbsarww.if so where.
Posted on Oct 11, 2013
I have a daewoofrg1820brb I've had it plugged in 4 2 hrs now freezer is cold but the bottom isn't getting cold
Remember that most all refrigerators only have cooling to the freezer... the refrigerator depends on stealing some of that cold to be cool, so here's my top 3 guesses...
Cause 1 The defrost heater is defective, so frost accumulates on the evaporator coils, and the coils will become plugged with frost causing the airflow through the coils to be restricted, and the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system after clearing any restrictions to the cooling fan and defrosting with a hair dryer.
Cause 2
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, bench test it for function and use a multimeter to test the motor windings for continuity. If the windings do not have continuity, (very odd) replace the evaporator fan motor. Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed or that an inadvertent bump has shut it off to the refrigerator compartment
Apr 09, 2016 | Refrigerators
Car running hot
This is either a cooling system fault which could be, thermostat, radiator or fan thermo switch, check that both top and bottom hoses are hot, if one is cold the thermostat isn't opening, check to make sure the radiator fans are turning on. If the thermostat is opening and the fans are turning on you need to take the car to get the cooling system pressure tested as you may have a leaking head gasket.
Mar 08, 2012 | 1995 Cadillac DeVille
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
The freezer gets very cold, but the bottom where the milk and vegetables does not get cold.
One of two things has happened. Either your evaporator fan has stopped working and not forcing the cold air down the cooling tubes to cool the refrigerator or the cooling tubes have iced up and the cold can't get to the refrigerator side of your unit - which is generally a defrost circuit malfunction.
If you don't feel air flow in the refrigerator section, then I am on the money. First check the fan and see if it is turning, if not replace. If it is turning, then you will need to use a hair dryer to defrost the dreezer and air tubes. Then troubleshoot the defrost circuit which is normally made up of a defrost heater, defrost thermostat and defrost timer.
Jul 13, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Fan in freezer runs and is cold. No air is coming
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 17, 2010 | Amana ABB1927DE Bottom Freezer...
Iam trying to find out why my fridge does not get real cool on the bottom but the freezer freezes up i have a dometic 2820
Check to make certain that the freezer fan is turning. This fan moves cold air from the freezer compartment to the refrigerator. If it's not working properly, you do not get good distribution of the cooled air.
It's likely behind an access plate in the freezer. If you can't hear it running, remove the access plate and look at it. If it's not turning, you will have to replace the fan motor.
Oct 15, 2009 | Refrigerators
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
