Question about Hoshizaki EV9655-11 / HC-H / 4HC-H Water Filter Cartridge
How to change out the Hoshizaki 9655-11 filter
Hoshizaki km - 280 mah ice maker not making enough ice
A few simple things to check is the condenser for dust. Blow it out. If their is a water filter going into the unit change it. Get some ice machine cleaner and follow directions. Do these things before calling anyone out.
Aug 12, 2012 | Hoshizaki Freezer Commercial Ice Machines...
3 beeps every 3 seconds
This usually occurs when there is a water supply issue. If you remove the front cover and expose the right side of the unit, you will see (at the top right) a panel with a black button on it about 1/3 the way in. USE A FLASHLIGHT to locate it.... there is an electrical shock hazard here.
Push the button and the beeps will stop. If the warning recurs, check for water pressure to the unit.
First, if you have a filter system, crack the nut at the entry to the filter just enough to see if water is present there. If not, go to the source and check the angle-stop... change it, or open it, as required.
If you have water at the filter inlet, do the same thing (after tightening the nut you loosened) at the outlet. No water?..... change the filters. Water present?... do the same at the entry to the ice machine.
Water at the entrance? Turn off the water and remove that fitting to expose the inlet solenoid valve and examine the strainer. If clogged, remove and clean the strainer.
Beyond this, you will need a technician to deal with the issue. Call the Hoshizaki factory at 1*800*438*6087 to find a factory-authorized service company in your area.
Jun 14, 2011 | Hoshizaki Freezer Commercial Ice Machines...
System working make smell ice filter clean water flowing
check the float. May need to be lowered. Also, check the length of the freeze cycle. Should be at least 20 minutes but usually longer on Hoshizaki machines
Oct 16, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine: my hoshizaki under the counter ice machine gradual...
Check condenser coil which is the coil on back with fins, sometimes with metal.mesh filter. If dirty or clogged up clean filter, blow out with air or brush and rinse out, careful not to bend fins. Sounds like issue to me. Unless the dump valve may be leaking by
May 18, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Please Heal
starving for water. clean or replace water filter or adjust water float assembly that determines how big cubes are. probably not getting abundant water during timed fill sequence. no water equals little ice.
Sep 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-500MAH not making ice
Look at water solenoid valve when the unit is running in ice mode. Check to see if the water is shuting off completely. If the water valve does not close properly it will keep adding a little bit warm water to the ice a slow down the ice production.
Sep 21, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki EV9655-11 / HC-H / 4HC-H Water Filter Cartridge Logo
62 people viewed this question
Top Hoshizaki Water Dispensing & Filtration Experts
ray gallant
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Tom Chichester
Are you a Hoshizaki Water Dispensing and Filtration Expert? Answer questions, earn points and help others
