Question about Protron PLTV-32 Television
Dark streak haqs appeared on screen why
Dark streak on face of tv has appeared why
  • mishka11 Apr 24, 2009
    My problem is more of a dark stain starting from the right side of the screen and extending to near center in a mask like shape...started about a year ago...
    President:
  • Protron Master
  • 1,779 Answers
This can be either the Logic board or your LCD panel is defective. Best to have it diagnosed by a service co.
Posted on Apr 23, 2009
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
Can't get picture screen clean
If the dark streak is static, then is liquid in lcd panel.
Oct 24, 2008 | Polaroid Televison & Video
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Got a couple of dark streaks on my flat screen. More prominent in extreme dark scenes and light scenes
    you will want to go into your tvs setting and restore factory defaults using the user manual if after doing this your still getting the dark streaks the television may need a new board. The cost of a new board and labor is usually cheaper than buying a new tv but if its still under warranty or you still have the receipt I would suggest returning it to avoid the headache
    Robb
    Sep 27, 2010 | JVC Televison & Video
    Dark shadow-like vertical streaks thru LCD screen (Sharp)
    Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
    Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
    Hi, i am Lata and the problem i face is the screen appears dark with circular dots resembling stars in the sky on a dark night. Images cannot be viewed and when i click there appear some horizontal lines....
    hi, i am del and the problem i face is the screen appears dark with circular dots resembling stars in the sky on a dark night. images cannot be viewed and when i click there appear some horizontal lines. what could be the problem? Can you help please? Rgds del
    Apr 21, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
    TV has dark streak on one side of screen.
    Your TV has a bad light tunnel. This part is inside the light engine. A qualified tech will have to replace it, but the part is available. Once it is replaced the TV will be as goog as new. Please take time to rate this solution and let me know if I can be of further assistance
    Dec 13, 2008 | Samsung HL-S5687W 56" HDTV
    Dark vertical lines on tv screen
    looks like lcd panel is off.the cost is abit less of anew tv!
    Jul 07, 2008 | Televison & Video
    Green wave-like color distortion over reds
    do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
    Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
    Brightness and volume
    The dark picture is a bad capacitor for the screen or drive voltage for the picture tube driver transistors. The other problem of streaking is one of the same. Thats the indication that a capacitors defective . It could in a rare cas ebe a defective or gassy crt as well but 99% of the time when a crt is said to be gassy its nothing more then poor drive to the crt. Good luck
    Jun 13, 2006 | Mitsubishi CS-40507 40" TV
    Protron PLTV-32 Television Logo
    194 people viewed this question
    Top Protron Televison & Video Experts
    Jaime Hernandez
    Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
