Epson aculaser c1000
My Epson has a streak of no toner. I the print head laser dirty. Can it be cleaned
SOURCE: Epson Aculaser C1100 will not print properly after changing black toner
I have had this problem with a couple of our C1100's the solution is simple but a bit fiddly.
open the lid and remove the photoconductor unit. what you need to do is clean the glass panel through which the laser shines (it is there honest). It id directly behind the toners but down near where the paper sits. Look at the photoconductor and see where the blue roller sits in the printer. This roller has the laser shone on it and then picks up the toner relaying it onto the belt in the photoconductor.
What i did was get a wad of strong tissue and use a screndriver to wedge it down the rear of the toners (in between the toners and the black plastic bar as you look into the printer with the photo conductor removed) and then slide it back and forth. I actually learned this one form some Minolta QMS printers we have, but the glass plate was in plain view on those.
Basically what we had happen was that some toner had dropped onto the glas and was blocking the laser from hitting the roller and this lead to blank (or faded) strip along the length of a page.
I suppose a smallish paintbrush would do the same thing.
Posted on Dec 23, 2008
  • 684 Answers
SOURCE: Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Posted on May 27, 2009
  • 11 Answers
SOURCE: How do I clean print heads re Epson Aculaser c900
you can clean print head unit
first remove opc and transfer belt ,then move front cover,then rmove
the Drum Unit Slide Cover,then
Remove the Laser Lens Cover.
now you can see printhead unit .Clean it and its ok.
Posted on Sep 06, 2009
SOURCE: Epson Aculaser C2600 Service code E144
This is a Transfer Belt Error - "Worn Out".
This is not a consumable item. Have had to contact Epson direct who have arranged for a service engineer to replace the offending item.
Posted on Nov 13, 2009
SOURCE: epson aculaser c1100 not printing right hand edge
The problem may well be that the drum needs cleaning. There is a plastic flap on the rhs of the machine. Open that and you can pull a long lever out. You also need to let down the front cover and pull out the lever on the right hand edge that faces you. Then extend the long lever at the side as far as it can go and push it in and out a few times. This should solve the problem. Put the front lever back and close the cover. It took me ages to find this - Epson are not good at highlighting it,.
Posted on May 08, 2010
Printer Driver for Linux : Epson C1000
Hello
Try these links.
driverscollection.com/?...ACULASER%20C1000...Epso... - United States
support.epson.ru/upload/library.../howtoinstallprinterdriver_linux.pd
www.downloadsarea.com/Free_driver-epson-aculaser-c1000-linux/
http://www.dataentryjobs.us/67948.html
Feb 09, 2012 | Office Equipment & Supplies
Keep getting Blotches on the printed page and unwanted streaks. I have tried cleaning it but no change?
The fuser roller is likely dirty with bits of toner. Rotate it and clean thoroughly.
Apr 09, 2010 | Epson Aculaser C1100 Printer
Jun 07, 2009 | Epson AcuLaser C1900 Printer
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
thanks
Apr 29, 2009 | Epson AcuLaser C4100 Printer
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Epson c1000
hmmm..those fuses are there to protect inner mechanisms..sounds like your laser is running on overload. Is there anything jamming the paper path?
Mar 08, 2008 | Office Equipment & Supplies
Epson AcuLaser C1900 paper jams and almost no ink
If paper jam occurs frequently, wipe the pickup roller with a clean dampened cloth. Follow the steps below:
  1. Open Cover AB of the printer.
  2. Open the cover below the paper path roller.
  3. With a clean dampened cloth, wipe the pickup roller.
  4. Close Cover AB.
If the glass on the print head filter is dirty with toner, wipe it with a clean cloth. A vertical white line may appear in the printout. Follow the steps below:
  1. Open the front cover.
  2. Tilt the waste toner collector and pull it out.
  3. Grasp the handle of the print head filter with your fingers and gently pull it straight out of the slot. (**Note: Be careful not to spill toner that has accumulated on the print head filter. )
  4. With a clean cloth, wipe the glass surface of print head filter.
  5. Hold the print head filter by the handle and gently insert it all the way into the slot.
  6. Reinstall the waste toner collector.
  7. Close the front cover.
The print quality problem might be something as simple as turning off the Toner Save mode using the printer driver or the printer's control panel menus.
There may be a problem with the photoconductor unit. You may need to replace the photoconducter unit.
Or it might be something rather more serious (hopefully, not)Print out a status sheet. If a blank page is ejected, the problem may be with the printer. Turn off the printer and contact your dealer.
Jan 04, 2008 | Epson AcuLaser C1900 Printer
Epson c1100
Yes, they do make this model, I'm using one now. I had the same problem
The solution for me was to clean inside of printer thoroughly, with the C (or whatever) cartridge removed. The sensors get dirty.
Sep 04, 2007 | Epson Aculaser C1100 Printer
Epson al cx11nf print problems: Lines on side of output
This could be caused by a dirty lens on the laser unit. Try cleaning the laser window. Open the front panel (where you change the toner) and the right you will see a blue lever/handle - pull it out towards you. Now on the right side panel of the printer you will notice a little plastic panel about 2"x0.75" - open that and you will see inside another handle. Pull this handle out and back in a few times. This draws a cleaner pad across the lens. If toner has fallen onto the lens it makes the are it has fallen onto create blank lines on the print. If this does not solve your issue then the next suspect would be the PCU. Just get another one (same as C1100 if you can borrow one) and try it.
Apr 28, 2007 | Epson ACULASER CX11NF All-In-One Printer
20 people viewed this question
k24674
jasbo
jasbo
