Question about Tamron 70-300mm f/4-5.6 Di LD Macro Lens for Minolta Maxxum
Tamron AF 70-300mm F/4-5.6 Di LD MACRO 1:2 - tripped and knocked lens, small part rattling inside, telezoom won't work
5 Suggested Answers
  • 134 Answers
SOURCE: Detaching Lens Hood
I'm not sure of the exact model number of your lens, but the hood should have a bayonet flange and rotating it in one direction or the other should allow it to then simply pull off.
Posted on Apr 21, 2009
  • 102366 Answers
SOURCE: Tamron 200-500mm F5-6.3 SP AF
Assuming the lens has a Nikon mount, yes.
Posted on Dec 02, 2010
Tri3mast
  • 747 Answers
SOURCE: Drop my Nikon D100 camera with a Tamron AF
First question "is it worth repairing" if it were mine I'd look to see what a new one is worth then divide that in half (cause that's what you might be able to buy a used one for) then figure about $120.00 for cleaning lubricating and adjusting the your lens. With your lens you know what you have, buying used might need the service. you are the one to decide. As for the second question "can I repair it myself" short answer no. If you have to ask if you can repair it then you don't have the necessary tools and general knowledge of how to dismantle and reassemble the lens (and have it work when finished). The lens took a hit and most likely set the inner and outer lens barrels out of alignment causing the inner barrel to slip out of its seal and or focusing gear and hang things up forcing it will break parts causing more repair costs. All else fails get an estimate before repair. Been there with a lens myself and after a couple a months without bit the bullet and had it repaired. Cheers best of luck
Posted on Jan 28, 2011
  • 3289 Answers
SOURCE: tamron AF 18-200MM XR Di II LD dust inside; how do I clean?
Dust and other small debris is drawn into the lens due to the vacuum created when zooming in. You can reduce the chances of drawing in dust and debris by slowly zooming in as opposed to rapidly zooming in.
Now that you how it gets in and how to help prevent it from getting in again, comes the bad news. There's really no way to disassemble the lens to clean it up at home. These are precision optics with many small moving parts that really need to be serviced in a dust free environment. You best bet it to contact Tamron (or authorized servicer) to learn how much it will cost to be cleaned by them. This will keep the warranty (if any) intact, too.
Posted on Feb 14, 2012
Tamron service manual
See if this site is of any help
http://camera.manualsonline.com/manuals/mfg/tamron/tamron_camera_lens_product_list.html
Jul 02, 2014 | Tamron 70-200mm f/2.8 Di LD IF Macro AF...
Was I sold a 'pup'? Tamron lens box says AF55-200mmF4-5.6LD MACRO. Can't find macro setting on lens or instructions. Looking at your site, Product Details says 'No Macro'. So what's...
Excerpted from a www.photo.net review of the lens:
Though the Tamron AF 55-200mm Di II LD Macro has "Macro" in its name, it's not really a macro lens. Maximum magnification is about 1/3 life size (Tamron spec it at 1:3.5) as you can see from the following image below, which was shot at 200mm and at the closest focus distance (0.9m/37.4"). This isn't too bad, but it's more of a close focus telephoto lens than a "macro" lens (bolding for emphasis added).
Sep 09, 2011 | Tamron 55-200mm f/4-5.6 Di-II LD for Canon...
Lens will not focus, just searches continualy, all other lenses work fine, was working fine then would not focus.
does the camera recognize the lens? I mean does the camera just say F--- or does it show all the information for the lens?
Nov 06, 2010 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Auto focus stopped working
Try cleaning the contacts on the camera and the lens, this is what usually prevents AF from working correctly.
Jul 26, 2010 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
I just bought a tamron di 2 AF 55-200mm f/4-5.6 LD macro for my nikon D40 and i can't get it to autofocus
That 2x is not AF-s compatible. It is the older Af style which the d40 does not support. Your camera store should have known this when they sold it to you, unless you bought it mailorder. Then see if they will let you return or exchange it.
Nov 04, 2009 | Tamron Autofocus 2x Teleconverter Lens for...
Tamron 28-200 AF Aspherical LD. Does it have manual focus? If yes, where?
There should be a switch just in front of the back of the lens marked "AF" and "M". Set it to M for manual focus, AF for autofocus.
Aug 30, 2008 | Tamron 28-200mm f/3.8-5.6 LD Aspherical IF...
Tamron 70-300mm f/4-5.6 Di LD Macro Lens for Minolta Maxxum Logo
32 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
