Question about Panasonic 1974 Microwave Oven Cookbook & Ne-7800 Sheet
How do I know wattage for 1974 recipes and convert cooking time to todays microwave (1200)
    Scholar:
  • 178 Answers
A 1974 Microwave Oven is probably not putting out more than 600 watts. You need to do a power test to determine it's actual power output. Place a 2 cup glass measuring cup with exactly 500 mL of cold water. Record the starting temperature of the water. Run the microwave on 100% power for 18 seconds, using a watch or timer, not the timer on the unit. Take the water out and stir it to make sure that there are no hot or cold spots in the measuring cup. Record the new temperature. Example: 78.4-64.1= 14.3.
Multiply 14.3 X 38.75= 554.125. The power output is 554 watts IEC. If the recipe is set for a 1200 watt unit, and your is almost 600 watts, obviously, you would double the cook time. Since this is rough, you need to experiment a bit. If the cook time is 10 minutes, check your product at 8 minutes. Be sure to push the stop button before you open the door when it is in cook mode. This will save wear and tear on door switches and leave the remaining cook time on the timer. Let me know how this works out for you..
Posted on Oct 28, 2013
5 Suggested Answers
  • 833 Answers
SOURCE: cooking temps
I'd try 50-60%.
Posted on Dec 20, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave wattage at different power levels
Usually the output power is adjustable from 10% to 100% in 10% steps relative to the full output power rating.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
grandadfixer
  • 99 Answers
SOURCE: Panasonic NE-8051 microwave
Probely needs new magnatron.
Posted on Oct 18, 2008
fathitkf
  • 1871 Answers
SOURCE: 1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
Posted on Apr 04, 2010
Testimonial: "Thnaks; If this is my problem, how is this switch replaced, is it a proffesional job , or simple? Thank you kind sir.T.K. tkeytanner@gmail.com"
I'm looking for recipes for a kenwood K28CW14
They are all online, but a microwave is purely a heating and cooking tool. you can use any recipe.
Cooking Chef Recipes
Sep 30, 2016 | Kenwood Microwave Ovens
What is the actual power wattage? on the back it says single phase 1200 w and out output is 800 w.I dont understand the difference
1200 watts in to operate the appliance then 800 watts power output emitted in microwaves for cooking.
Sep 16, 2015 | Microwave Ovens
My gammon joint is 1.194 kg in weight how long do I cook in the oven for
Based on a 1200 watt microwave. Increase time for less wattage devices.
Place in a large casserole dish with lid and cover with water.
Heat on High (full power) for 15 minutes then 15 to 20 minutes per 450g at Medium power.
Allow to stand before serving as always.
Feb 06, 2015 | In Microwave Ovens
Wattage for mc 1000b microwave
By the name I would think that it is a 1000 watt Microwave. Wattage as in cooking power is what you wanted? Running wattage, a 15 amp circuit will work fine. A 120 volt, 1000 watt microwave will use 13.4 amps (1,600 watts) of electricity in a full power cooking cycle. I think that covers everything! ..:)
May 16, 2014 | Magic Microwave Ovens
I need to know the wattage of my magic chef oven model 6898VV
Hi Nadia,
There's little to be found on the internet for this model oven now. There should be a name plate / manufacturer's sticker either inside the door - on the jamb; or on the rear near the power cord. If you see a rating given as "120VAC / 1200W" this would indicate INPUT wattage, which would be higher than the amount used for cooking. A typical 1200W rated microwave might have 800 - 1000 Watts of cooking power. If there are 2 ratings for wattage like 120V / 1200W / 850W; the 850 Watts is the amount of cooking power. The cooking power - or wattage - is always lower than the total wattage. If you see a rating somewhere that indicates 900W cooking power, then that would be the cooking power of the oven.
If you're not satisfied or unsure about the information you're finding on the oven - or it is missing - you might want to contact Magic Chef Customer Service Department at (888) 775-0202. They should be able to help you - or pint you in the right direction.
Apr 07, 2014 | Magic Microwave Ovens
I only want to find out the wattage of the Welbilt MR757T Microwave.
700 watts. Really unsuitable for most of today's cooking needs.
Aug 18, 2010 | Welbilt MR755T Microwave Oven
Question: Can the Tastiwave oven be used?
I don't own one but per the TastiWave Quick Start Guide (which can be downloaded as a PDF document), The wattage must not exceed 1300 Watts. In the Instruction manual and quick cook recipe guide (also a downloadable PDF document) it states that:
"The recipes in this booklet have been written for an 1100 Watt microwave oven. Please adjust your “cook times” accordingly. Microwave must have a revolving turntable and the interior
must measure at least 14” wide x 14” deep x 7 3/4” high".
I hope this answers your question ;-)
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Oct 06, 2009 | Sharp Microwave Ovens
I have a Jenn Air over the stove microwave oven JMV8000ADW. How do I compare 1 through 10 power of my oven (1450 wattage)when looking through microwave cookbooks of lesser wattage? How do I compare their...
Power level 1 = 10%, 2 = 20%, 9 = 90%, etc.
So 1000/1450 ~ .69, so use power level 7.
Sep 06, 2008 | Microwave Ovens
I recently bought a microwave/convection oven. Model #JES1290SK 02. I understood that cooking time would be lessened for most recipes when using the convection oven, but it takes longer every time....
GE Customer Service is here, and they should be able to help you.
They may refer you to the Answer Center.
Aug 12, 2008 | GE Microwave Ovens
Panasonic 1974 Microwave Oven Cookbook & Ne-7800 Sheet Logo
64 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
