Question about JVC AV-32750 32" TV
Green shadow i have a green shadow down oneside then goes purple changes sides any ideas
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is due to degaussing circuit. it has developed due to changing the side or turning tv or any thing is lying near tv which has got magnetic effect. solution 1 put of tv for 15 minutes 2 do not change direction while watching tv . 3 remove magnetic thing like speaker if is near tv. still if you donot get the result call tech.to degauss it with degaussing coil. it is 2 minutes job. good luck.
Posted on Sep 25, 2007
SOURCE:
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
Were does the blue green and purple wire go for itrp fm transmitter
Blue goes to A, Purple goes to G and Green goes to V! I need to know what the pinout is for the headphone jack side
Nov 21, 2011 | Griffin Technology iTrip Auto with...
Stereo wiring color code for a 94 dodge shadow
1994 Dodge Shadow Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 5? x 7?
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
Nov 14, 2010 | Dodge Shadow Cars & Trucks
Got a purple stripe from the lower edge of the screen center to center. gradient to the middle of screen. like 100 lines wide. any hints THANKS michi m
if it's sharp edged and inline with the pixels, you have a bad green lcd panel. if it's fuzzy and random, you have a burnt light filter. either way, it's an optical engine issue. you can try to go into the case, remove the ribbon cable for the green lcd (unlock the ribbon clip first) and reinsert it and lock it down. if that doesn't work, you'll have to replace it.
Dec 02, 2009 | Sanyo PLC-XP51 Multimedia Projector
Purple and green strip/shadow around all the images and at the bottom
Either a bad optical block or possibly a bad LVDS cable, you need a qualified tech to know for sure
Sep 19, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
HITACHI 42 INCH HD
Convergence Amp IC issue....originals are STK392-110..replace
W / upgrade Stk394-160E Hitachi part # CZ 01341 and check nearby resistors for overheating............................T.
Jan 07, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence
covergence amp ic"S need to be replaced.
Aug 16, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
105 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
