Question about HP DesignJet 1050c InkJet Printer
System error hpdesignjet 1050c error 09B300 007A0EED
    Novelist:
  • HP Expert
  • 175 Answers
09Bxx0 errors relate to hdd read fail,#
there are two causes for this -1) the Hdd has indeed failed
2) the power supply in particular the hdd power supply(part of the main PSU) has failed- easiest way to see is connect a diferent hdd to the machine and see if it spins up if it does replace the hdd if it does not then replace the psu
Posted on Feb 12, 2014
3 Suggested Answers
seeker5211
  • 1089 Answers
SOURCE: HPdesignjet T610 error code 08:11
The 8 code is a formatter or front panel problem. Try reseating the formatter and its cables. Also reseat the front panel cable.
Basically it means that there is no communication between the front panel and the Main board. Turn the printer off and unplug it from the wall. Reconnect the cord and power up. If it still fails, the formatter or the main board or the front panel will have to be replaced. Get a tech to check it out.
Posted on Oct 31, 2010
  • 33 Answers
SOURCE: system error 1290 on hpdesignjet
The Piezo Drive IC on a Printhead is too hot (85oC or higher) or too low (- 10oC or lower). If it the IC that's to hot..
Posted on Oct 09, 2011
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
Designjet 1050c system error 0A0050
0A0050 indicates a leak in the tube system has been detected. Can be caused by condensation, but more likely the tubes are leaking and need to be replaced.
Sep 01, 2014 | HP DesignJet 1050c plus InkJet Printer
System error 1290 on hpdesignjet 9000s
Aug 21, 2011 | HP DesignJet 9000 InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
It is about hpdesignjet 500 :- Problem- Severe error: 0X3010002 Task - tmech file - sequence.c line - 758 Please help I am using it in far away in salma dam project in afghanistan and no technical help...
System error 21.10 says to replace the service station/Aerosol fan Assembly.
You've got real problems if you don't have a service manual or parts.
good luck
Dec 05, 2010 | HP DesignJet 500 InkJet Printer
Oct 31, 2010 | HP Designjet T610 InkJet Printer
My ploter is ready mode when printing giving error 0a0010-00000001 system error and not working model hp designjet 1050c pl resolve my issue
System Error: 0A0010
Problem
Description:
Problem in Pressurizing the Air System.
Corrective Action: Try the following:
n Replace ONE Ink Cartridge at a time, checking if the error code
disappears.
n Check all the cables of the APS and make sure they are correctly
connected and are NOT damaged.
n Check all the tubes of the APS and Tubes System and make sure
they are correctly connected and are NOT pinched or damaged.
n Faulty APS Sensor, APS Valve or APS Pump. Replace the
complete APS þ
WARNING Only replace one component at a time and check if the error has
gone before replacing another component. Using this procedure
you will be able to determine exactly which component failed
Oct 29, 2009 | HP DesignJet 1050c InkJet Printer
I am getting a system error 0C003200000003 HP designjet 1050C
System Error: 0C0032 (Continuable)
Problem
Description:
Drop Detector not Calibrated for all Printheads.
n Perform the Service Station Calibration þ
n Replace the Drop Detector Assembly þ
n If the Error Code continues, replace the Electronics Module þ
this is a continuable error.
Sep 25, 2009 | HP DesignJet 1050c InkJet Printer
System Error 060308000008 on HP Designjet 1050C plus
that error show a problem with the pintheads
Remove ALL the Printheads and clean the flex contacts on the
Printheads and in the Carriage Assembly, if that dont solve the problem change printheads, if after that have the same problem call HP, was a hardware error.
Apr 30, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
218 people viewed this question
Seeker5211
Seeker5211
