Question about Acer Aspire Computers & Internet
Laptop screen as tv monitor
I want to use the laptop as a tv monitor, I have a video adapter and video capturing software, but the screen options do not support tv/monitor mode. Is there any way to change this?
  • Despoina
    Despoina Oct 11, 2013
    Thank you all for trying to help. I am not trying to connect a second monitor, what I am trying to do is use only the laptop screen as a monitor. This is why I got the video capture software and a USB video adapter. All the drivers are up to date, all connections are right, the exact same setup is working on other people's laptops but not on mine. Changing the screen resolution did not make a difference, I tried that because someone suggested that my adapter won't give signal to an HD screen.
    I'll try to look into the chipset, as the laptop recognises the device (usb adapter), it just doesn't see what is being sent.
    Sergeant:
  • 252 Answers
Install the TV Tuner Card.
Posted on Oct 12, 2013
Testimonial: "It's already installed, thank you."
enuro12
  • 116 Answers
SOURCE: dual or mirror monitors
Their is a button located on the 1-9 keys, it looks like a little monitor. Maybe 2 monitors.
Hold down your FN key (Function) and press that button, that will turn on the svga connector. Also if you press it again it should keep both monitors on, and again will switch back to only the LCD.
Posted on Oct 11, 2007
MrARCADIAN
  • 284 Answers
SOURCE: Laptop monitor problem
sounds like the inverter has gone out or backlight of the laptop has gone out.
you would normally see a logo or something when you removed the TV from it, you can boot dual lcd with laptop on and TV. so i doubt something is turned off.
when hitting FN and F5 usually take about 3 sec to refresh the screen. but looks like the LCD screen on the laptop has failed and need to be replaced or the Backlight or Inverter has to be replaced.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Posted on Jul 15, 2008
pankaj_dic
  • 1252 Answers
SOURCE: Display is wrong - only 3 resolutions available
install the display drivers, then check
Posted on Oct 28, 2008
SOURCE: attaching external monitor to acer aspire 3682wxmi
I wouldnt put something like that in, sounds like your having a driver issue,
Posted on Jan 04, 2009
Geekman
  • 32281 Answers
SOURCE: Black screen- laptop only works with external monitor
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
If your Dell has a S-video output it could connect to a TV or a video device, which allows for a TV option.
Posted on Jul 24, 2009
Easycap software
Google video capture software. You'll find plenty. Windows has some already on your PC.
Jan 07, 2014 | DekCell EasyCap USB 20 Video Capture...
Tip
Followed step by step, still no video or sound. just a blank screen. :0(
Ulead Video Studio SE DVD how to run on Windows7 64 bit systems by Not you. Drivers updated now has drivers for XP Vista and Windows 7 7/16/2010 Getting started,you will need another program its called USB-AVCPTSetup_For_Win7 you can get it here... download links are at the bottom of page.Do not install at this point save to your desk top! Ok your ready Do not plug in your Easy cap usb drive. 1. Put the EasyCap disk into your CD Rom When auto play starts click Run HAutorun.exe a window will open DO NOT INSTALL THE DRIVER !!!! 2. click Install Video Studio,complete the install adding your code with no driver reboot when asked. after reboot remove the disk you will not need this anymore. 3.DO NOT INSTALL THE EASYCAP USB DRIVE YET. 4. Install the software you saved to the desk top (USB-AVCPTSetup_For_win7) reboot your system. 5. Plug in the EasyCap USB stick and wate till the driver installs this will be done auto,in a few seconds. 6. Sorry to say but you need to reboot now. leave the USB drive in its port. You are now installed but your cam will only show a black screen at this point,its ok we are now going to resolve that. Start the Ulead Video Studio. During the start up you'll have the choice of VideoStudio Editor or Movie Wizard click the 16:9 ckeck box at the bottom then click VideoStudio Editor. New window will open click Capture,now look for capture video button on the right side of the black screen,click it Just to the right you will see an Options button click. A drop down will show,look to see if input source is in dark letters,if so open and set source to NTSC/M and composite video is checked. If the input source is greyed out,open Capture properties directly under the input source,a new box will open click properties a new box will open this box will have 3-4 tabs you only need the first tab called Image tab under video sources click ntsc/m and composite video click ok click ok again thats it you should now have video,After any restart you will need to reset ulead up again,you should be good to go...... Hope this helps :-} Here are some pic's to help.Note after the instalation,if you move the Easycap usb drive from the usb port it was installed in and input it into any other port it will not work,the driver will need to be reinstalled!!! 09c750d.pnge0aeff9.png78f955a.png New download links For Windows XP/VISTA/7 32-Bit, please download Windows 7 64-bit This web page I have not goten any link to open but thought I'd add it so you all can see it,if anyone gets it open please post any or all links for us all. Thats all for now I'll upload more as I get them. ps working with a company rep now,update for easycap d60 4 input style,If not getting a picture on input 1 move to 3 for setup and one camera setting.
on Aug 07, 2011 | DekCell EasyCap USB 20 Video Capture...
Easycap dc60 wont work on my windows 8 laptop
Guys who need windows key can go site www.vanskeys.com to got. My key got here and after i used is great works.
Dec 25, 2012 | DekCell EasyCap USB 20 Video Capture...
How do I watch tv on laptop with easycap?
The easycap is not the best software to watch tv on laptop ,
There is much more better softwares , check out this link for the best satellite software ever.
Jun 14, 2012 | DekCell EasyCap USB 20 Video Capture...
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
Ho do i connect my laptop to my flat screen samsung tv
There are 3 ways ways to do this from the left side of the laptop.
1) S-Video-out jack [Connects an optional S-Video device such as a television, VCR, camcorder, overhead projector, or video capture card.]
2) External monitor port [Connects an external VGA monitor or projector.]
3) HDMI port (select models only) [Connects an optional video or audio device such as a high definition television, set-top box, DVD player, or any compatible digital or audio component.]
Your TV will have one of those interfaces. You just need to look at your user manuals for both the Laptop and TV
Take Care
Oct 03, 2010 | HP Pavilion dv9000z Notebook
Can i connect my acer aspire 4730z to my television so i can watch dvds
Yes of course.
First of all you will need to identify the available input ports on your TV. An RCA port is generally standard nowadays and it consists of a red, a white and yellow coloured reception ports (the colours may differ between tvs, i.e black instead of red). The red and white are for stero sound and the yellow is for video.
Modern TV systems also have a VGA adapter which is small flat port like the ones on a computer screen. This is usually blue.
A third option is an S-Video port, which is round in shape.
To connect your laptop using the RCA port, you will need an S-Video to RCA converter. You connect the S-Video to the port on your latptop, and through the converter to the RCA yellow port on your TV. For sound you will use another cable that connects to the headphone jack on your laptop and then splits to a white and a red cable to connect to your TV.
If you have VGA port on your TV, then connect the VGA port on your laptop to the VGA port on your TV. No converters needed. For sound you will use the same approach as above.
To use the third option you will need to have an s-video out port on your laptop and you will connect it directly to your TV s-video port. For sound, again you will use the approach as the rca solution.
Then, using your remote control, select the AV mode or depending on your TV select the PC or VGA mode.
Finally, to transfer the video from your laptop to your TV press and hold the Fn key on your laptop's keyboard and then the F7 or F9 key. (It has s small TV icon on it).
That's it!
Regards,
nicolasiac
Apr 08, 2010 | Acer Aspire 4730-4947 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
