Question about Brother MFC 8220 All-In-One Laser Printer
Can not send outgoing faxes on brother mfc-8220.
    Problem Solver:
  • 17 Answers
There are a number of reasons why you may not be able to send a fax. Check your manual for troubleshooting tips. However here are some simple things to try.
1. Check to make sure the cord from the outlet in the wall to your all-in-one is plugged into the proper port. There are usually two ports that will accept your phone plugs on the back of machine. One goes to your phone or answering machine and the other one to the line that goes the outlet in the wall. It's easy to plug your cord into the wrong port. Try plugging your phone cord into the other port and see that works.
2. You may have a defective phone cord or the wrong type of cord. Most phone cords only have two conductors in the cord and others have four. Try replacing the phone cord with a known good phone cord and see if that helps.
Posted on Oct 23, 2013
2 Suggested Answers
ryeisenman
  • 9 Answers
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Posted on Nov 21, 2009
Brother mfc 8220 will not send faxes to certain numbers
The problem is not with your fax machines. If it sends to any fax number it so OK.
Jun 11, 2010 | Brother MFC-8220 Fax
Unable 2 send or recive fax
Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 15, 2010 | Brother MFC-8220 Fax
Nov 21, 2009 | Brother Office Equipment & Supplies
I need to replace the ADF Document Support piece on my Brother MFC-8220 fax machine. Do you know where I can purchase one?
I finally located a phone numbe for the Brother-USA Sales Dept. (888-615-9119). The part was $4 plus shipping and handling ($10 total). It took a bit of doing for them to identify the part and determine the part number. I had to fax them a machine parts diagram from the MFC-8220 manual. Go figure.
Oct 01, 2009 | Brother MFC-8220 Fax
MFC-8220
Its the CIS unit. Part number LE7949001. $70 retail price.
Aug 15, 2008 | Brother MFC-8220 Fax
Reinstalling driver for Brother MFC-8220
Hey,
The brother drivers and software require for the machine is available at
http://www.brother.com/E-ftp/info/index.html
Let me know if you need anything else.
Thanks,
Ekse
Aug 01, 2008 | Brother MFC-8220 Fax
Receiving Faxes
here is the manual try the troubleshooting sectiomn
http://www.retrevo.com/s/brother+8220++fax++manual
good luck
Dec 19, 2007 | Brother MFC-8220 Fax
Document to memory before sending
Here's the manual. Look at page 6-8. That tells how to turn on real-time transmission. You just need to do the same thing, except switch it to off when you get to that step. http://www.brother.ca/en/products/pdf/manuals/MFC8220-UG.pdf
Sep 06, 2007 | Brother MFC-8220 Fax
Brother MFC 8220 All-In-One Laser Printer Logo
61 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
