Question about Fujitsu fi-6130 duplex scanner
IRREGULAR STATUS IS DETECTED IN THE SCANNER - Fujitsu fi-6130 duplex scanner
3 Suggested Answers
TechSatya
  • 104 Answers
SOURCE: fujitsu 4750c Irregular status is detected in
If "Front Side Optical Alarm" appeared, clean the glass (small and large one) of the flatbed and carrier unit.
If the issue persists, then check if CCD harness or CR cable is disconnected? Connect the connector.
If the issue persists, then replace Front lamp.
If the issue is not resolved, then replace the Control PCA or Carrier unit or Optical unit.
regards,
Tech Satya
Posted on Feb 09, 2010
john_madd112
SOURCE: Fujitsu fi-5750C flatbed will not scan. I keep
Mine came with the same error message. If you look through the glass into the left front corner, you should see a spring loaded belt tensioner device. It merely hooks into the bottom plate against a spring to keep the belt tight. On my 5750C, the belt tensioner had slipped out of the base during shipping. The hardest part of inserting it back into the base was getting to it. Directions to do that are on this site at .../support/t484836-taking_apart_flatbed.
Posted on Nov 15, 2011
Printer is in use or an error has occured check status scanner driver will be closed closed
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Use a test print to CALIBRATE the scanner. if this wont help there is fault in the motherboard.
Nov 12, 2011 | Office Equipment & Supplies
Fujitsu fi-5750C flatbed will not scan. I keep getting an error "Irregular status is detected in the scanner. Anomaly in Flatbed motor operation. There are some codes: Sense Key = 0x4; ASC=0x580;...
Sep 20, 2011 | Fujitsu fi-5750C Flatbed Scanner
We are not able to get our Fujitsu fi-5120C out of status 8. We've turned it on/off unplugged it changed one of the pads (as it was bent). We left it alone for a day and it's still not working. Do you have...
Thank you for contacting FixYa.
Please clarify if the error is E8 or some different error. E8 error indicates that SCSI fuse is blown. When 5V, 3.3V fuse is blown, the scanner does not turn on and E8 error is displayed. Check the SCSI fuse status. The SCSI fuse is located in the Control PCA marked as TH2. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable. #Check the SCSI cable status.
- Other SCSI device malfunction. #Check the SCSI device.
1. Does the same symptom occur after turning OFF and ON the scanner?
To check, press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Check if the SCSI cable or other SCSI devices connected to the scanner cause this error. The scanner can work even after this error occurs. However, to remove this error you may have to replace the Control PCA.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Microsoft Word - P1PA03289-B30X6_03.doc matsubara 11.9999 Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Jul 15, 2010 | Fujitsu fi-5120C
Scanner not detected
I have the same problem with my Canoscan LiDE 25 scanner used sparingly since purchase in 2008. Last used 3 days back after a gap of a few months when it scanned a few pages and then stopped working. On connecting the scanner to my laptop on Vista Home Premium 32-bit it shows "USB device not recognized". No change in status after uninstalling drivers, cleaning my system, and reinstalling drivers from the Canon CD, or Canon US site, or Canon UK site. Even tried VueScan but this also does not recognize the scanner. I find it hard to believe that a Canon product stops working in barely 5-6 years even though it is very sparingly used and stored in the original packing when not in use.
Jul 03, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Black ink cartridge
you should be able to disable black ink printing by going to the printer preferences selection through your Windows OS printer & faxes function.
Alternatively, if you have loaded the printer monitoring CD that came with your printer then the ink status function should prompt you to disable the black cartridge if it detected it has run out.
May 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
PO300 DETECTED IRREGULAR FIRE HYUNDAI Entourage 2007 P0302 DETECTED 2# CYLINDER FIRE HYUNDAI Entourage 2007 P0304 DETECTED 4# CYLINDER FIRE HYUNDAI Entourage 2007
If the engine is still not warmed up yet and you take off like a bat out of hell, they will misfire occasionally. If it is a frequent problem change the spark plugs.
Jan 17, 2010 | 2007 Hyundai Entourage Limited Minivan
Fujitsu 4750c Irregular status is detected in scanner
regards,
Tech Satya
Sep 21, 2009 | Fujitsu fi-4750C Flatbed Scanner
Can't install my printer to my new pc...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi9
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu fi-6130 duplex scanner Logo
127 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
