Question about Vehicle Parts & Accessories
I bought used tires for my truck, they came on these 5 lug wheels I am trying to sell them now & need to know what vehicle they came off of,,, can ya help me. Information on sticker on wall of wheel is as follows --- finish: polished, size: 16x10, bolt pattern: 108.2, offset:-24mm, cap: N/I
    Problem Solver:
  • 17 Answers
First of all NEVER buy used tires
Posted on Oct 14, 2013
Testimonial: "wow that was helpful, take ya long to come up with that,,, thanks so much for 'helping' and for posting a 'solution' I have a winner on best answer!!! tires are great, like new & WAY cheaper than buying new, (some people don't have $ like that or of coarse new is the way we would all go) rims went to a ford just fyi ;)"
Will a standerd lug wrench work to change tire on this car
Hi Dickens:
Most vehicles come with a wrench sized correctly for removing wheel nuts.
- "Lug nut" wrenches are available in various sizes.
You will need to try the wrench you have on the wheel nuts on your vehicle.
- Some of the wrenches have several different sizes, so when you find the one that fits snugly, you can mark it with a black felt or with paint so that you'll know which one to use in future.
Cheers
Jan 14, 2016 | Cars & Trucks
Lug nut issues
Your factory custom wheels are designed to use a specific lug nut, most of these lugnuts today include a built in washer that contacts the wheel surface. Your maintenance of re-torqueing the lugnuts after 100 miles following wheel removal is exceptional, and textbook...(some wheel manufacturers recommend this after 50 miles:) I am a long time wheel person through many years of performance wheel applications. My guess would be that a previous owner had installed custom wheels, and removed them at time of selling your Santa Fe...they mistakenly left the aftermarket lug nuts on your car...and these lug nuts do not contact your wheel where they should be to remain tightened...Don't buy new lug nuts unless you can test this possibility first...All salvage yards would have inventory of factory wheels and lugnuts...Also shop on line...confirm the size of your wheel studs...ie 12 mm rht..."right hand thread" and search for someone selling factory wheels...many auto parts stores will confirm your wheel stud thread size any offer replacement sets too. Hope this helps.
Jan 17, 2014 | Hyundai Cars & Trucks
I am trying to replace a wheel lug on my 01 Diamante can you help.
Buy new lug nuts for your vehicle. These can be purchased at an auto parts store or a tire and wheel store in complete sets, online at wheel retailers and through the dealer that sells your vehicle. Be sure to have your make and model of vehicle available so that you get the right lug bolts.
  • 2 Loosen the lug bolts on your vehicle with a lug wrench or a socket and ratchet. Raise the vehicle with a floor jack at the corner where you are going to replace the lug nuts. You can use the jack to support the vehicle while you replace the lug nuts or you can use a jack stand. If you use the floor jack, be careful as you remove and install the lug nuts.
  • 3 Finish removing the lug nuts on the wheel. Thread the new lug nuts onto the studs that the wheel is mounted on. Tighten the lug nuts as tightly as you can with the wheel still in the air. At some point the wheel will start turning.
  • 4 Lower the vehicle back to the ground. Tighten the lug nuts progressively in a crisscross pattern with a torque wrench to the specifications of the manufacturer. This will vary from make to make but is usually around 90 ft-lbs. Repeat the above steps for the other three wheels.
  • Oct 30, 2011 | 2001 Mitsubishi Diamante
    Do you think going from a 4 lug to a 5 lug using
    my opinion i would stay with the 4 lug you can run into some longterm issues with the adapters such as tire wear and possible some premature wear on parts
    Oct 18, 2009 | 1991 Honda Accord
    Romoved lug nuts, but tire will not come off. Has
    jack up and add another support remove all but 1 lug the remaining lug nut loosen about 3/4 spray around center hub and around each lug nut with a lubricant wait 5 min get a piece of wood and a hammer or a big rubber mallet and start hitting around the back of the tire the wood and hammer ,the wood is to protect the rim hit the wood with hammer not directly on the tire could bend lip of rim should break loose from hub
    Sep 27, 2009 | 2007 Dodge Grand Caravan SXT Minivan
    Getting front tire off to check brakes. already
    it seized on the hub is all. lay on side, kick with the back of you heel without laying under vehicle. thread on a lug a few turns so it doesnt take off. be carful! make sure its hoisted safely with a block or stand for back up
    Sep 04, 2009 | 1999 Honda CR-V
    Front wheel lugs are breaking
    Hello, Are you using the factory wheels? If you are using aftermarket wheels, the wheel center might not be fitting snugly on the hub like it should causing the wheel to move slightly. The bolts aren't the only thing you need to keep the wheel centered. If the wheel starts moving up and down it will eventually break the studs.
    If you find this information to be correct would you please enter a "fixya" rating.
    Thanks, Gator241
    Feb 10, 2009 | 2000 Dodge Ram 1500 Truck
    How to change the tire
    First off did you Know this ?????
    Make / Models : Model/Build Years:
    GMC / 1500 2004
    Regency / Chevrolet 1500 2004
    MANUFACTURER: General Motors Corp.
    NHTSA CAMPAIGN ID Number : 04V240000 Recall Date : MAY 14, 2004
    COMPONENT: Tires: Temporary/Emergency Spare Tire
    Potential Number Of Units Affected : 285
    SUMMARY:
    The spare tire and wheel assembly that was provided on certain conversion vehicles will not fit on the front wheel hub due to offset of the wheel. However, it will fit on the rear wheels.
    CONSEQUENCE:
    If someone has a flat tire on the front wheel, they will not be able to install the provided spare tire.
    REMEDY:
    Dealers will install a spare wheel with the correct offset. Owner notification began on June 11, 2004. Owners should contact Regency at 1-800-989-4727.
    NOTES:
    Customers can also contact The National Highway Traffic Safety Administration's Auto Safety Hotline at 1-888-DASH-2-DOT (1-888-327-4236)
    SPARE TIRE is Under rear of truck use Long Cranking in HoleClose to Lisence Plate to Lower it Down Cranking Counter Clockwise. Wing in center of Wheel pokes thrugh Hole in Center of wheel
    Reverse Procedure to Put old tire in Tire Storage Compartment
    1. Locate Jack & Wheel Lug Nut Wrench
    2. There is Directions as to where to placse the Jack for raising Truck Where Jack is Located
    3. Set Park Brake Chalk tire if possible & Hazard lights (If on the Roadside)
    4. Loosen all Wheel Nuts on said wheel before Raising Vehicle
    5. Place Jack In Recomended Placment spot
    6. Rear is Normaly on Axel close to Shock
    7. Front is Normaly on FRAMERAIL
    8. Raise vehicle untill tire is 3-4 inches off ground as Flat will Lower vehicle
    9. Remove All Wheel Nuts And Wheel
    10. Place new wheel/tire on Vehicle and start all nuts
    11. Tighten nuts as tight as Possible then Lower Vehicle Untill tire touches ground Good
    12. Now Toque Wheel Nuts as tight as Possible with hand tool
    13. Lower vehicle all the way down
    14. Put away tools and Reliece Park Brake
    15. Torque should be around 100-130 foot Pounds
    I Hope this is What You Wanted Its Off the Cuff as My Reference Books done have this Procedure.
    Jan 26, 2009 | 2004 GMC Sierra
    Jeep wrangler change tires..
    Changing tires on a 2007 Jeep Wrangler is no different than a typical vehicle. Any local service facility can help out.
    If you are wanting to do it yourself:
    1. Break the torque on the lug nuts while the vehicle is still on the ground. 2. Jack up the axle using the jack in the trunk (under the panel in the trunk floor) 3. Remove the wheel and tire 4. Replace with the spare or a new tire 5. Tighten the lug nuts to 85-90 ft-lb of torque, make sure you tighten in a star pattern.
    Jan 25, 2009 | 2007 Jeep Liberty Sport
    2 lug bolts on my 4 lug bolt tire broke off.
    assuming the bolts that broke, broke while the vehicle was in motion,
    the wheel is bent
    when the broken bolts were at the bottom, there was twice as much leverage between the wheel edge and the other bolt, and nothing to restrain the near edge, it would bend like cardboard
    replace the wheel
    Nov 05, 2008 | 1995 Mitsubishi Galant
    Vehicle Parts & Accessories Logo
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
