Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
When I turn my macbook pro laptop on all I see is an envelope with a question mark
  • 26 Answers
The computer cant find a start up directory so your Harddrive may be corrupted or physically bad. But there are other causes so...
First thing to do is turn it off, remove any connected devices or cables, unplug the power supply and remove the battery. Wait a minute or two then replace the power supply leaving the battery out and start the macbook while holding down the SHIFT key on the keyboard to start in Safe mode. If that works you're lucky and you can restart the computer normally (no shift key) replace the battery and any connected devices one at a time (with a shut down in between) to see if one of your devices was to blame. If that didnt work you will need to start the computer from your OSX start up DVD to repair your start up directory/harddrive if possible. See this link http://support.apple.com/kb/TS2570 for more details. let me know if you need more help.
Posted on Oct 11, 2013
How can I get this printer to print envelopes?
You have to set the correct paper size in the print dialog box.
Dec 14, 2012 | Apple MacBook Pro Laptop Computer with...
My apple macbook air shows a question mark when i turn it on
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
May 22, 2012 | Apple MacBook Air
Flashng question mark on my macbook pro 13" when starting up,dont have any discs to aid recovery
Welcome to Fixya. If you have a flashing question mark on the screen please follow the steps on the link below.
Flashing Question Mark Fix
Please let me know what happen. Thanks for using Fixya.
Aug 18, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have the macbook pro since February It has a question mark blinking on the screen
where is the questionmark? the questionmark usually means somethings supposed to go there and its missing
May 11, 2011 | Apple MacBook Laptop Computer Mac...
Which is the best laptop?
This is very subjective, but either the MacBook or MacBook Pro because the MacBook Air is more expensive than the Macbook because it is thinner, but does not outperform it.
Now between the MacBook and MacBook Pro there are so general guidelines: -If price doesn't matter, the MacBook pro is the best Apple laptop because of its RAM and Aluminum body finish, also its Sandy Bridge processors and its new Thunderbult Port.
If price does matter, than there are some general deciding factors:
  • What do you do? If you work on your MacBook pro using PhotoShop and Movie Editors and a lot of software- the MacBook Pro is what you want. Also if you game, the MacBook pro is awesome.
  • Is it just for fun? If you want this laptop just for recreational use and not for games requiring heavy processing power for graphics, just get the MacBook.
Bottom Line: MacBook Pro is the best Mac laptop
Apr 06, 2011 | Computers & Internet
Won't turn on
The problem in blank white screen is the display (LCD). Send it to a technician for repair. The blinking folder with a question mark is conflict on drivers. Have you installed a software lately? If you do please uninstall it. Maybe that is the cause of having a blank white screen.
Jul 12, 2010 | Apple MacBook Pro PC Notebook
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
66 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
