Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Motor does not switch to carpet - Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
  • Corrie Williams
    Corrie Williams Oct 21, 2013
    Yes, I did take my vacuum in for a new clutch, $125 repair and good to go another 12 years I hope!
  • Corrie Williams
    I took my vacuum in to a repair shop and the clutch was replaced. $125 repair bill and hopefully it goes for another 12 years!
    Sergeant:
    Champion:
  • Dyson Expert
  • 357 Answers
You need the clutch replaced. All Dyson DC-7 and DC-14 machines need to be serviced annually and have the clutch replaced if you want it to perform properly. Take it to your local vacuum repair shop to have it serviced. The good news for you is, most of the newer Dysons only last a couple of years and are disposable. Yours is repairable.
Posted on Oct 21, 2013
My vacuum switch will not come on in carpet position and will not vacuum correctly on the carpet
It's hard to determine without knowing what brand and model you have. It could be the brush roll switch if you have one, it could be the motor that turns the brushroll if your model has one. It could be an electrical short. Check for a fuse in the power line inside your vacuum.
Jan 15, 2017 | Vacuums
I have a Dyson dc17 I have changed the belt cleaned the brush bar clean the bar motor reset the switch and still when i vacuum the brush bar just stops does not rattle. does not do it on bare floors or...
hooked rugs produce the highest amount of friction opposing the brush rotation, which can over heat the drive motor. try using a height setting that raises the brush so that it barely touches the pile. If this issue has been going on for some time, you may need to replace the drive motor.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Carpet beater not working
It could be one of many things: switch in handle or switch in motor compartment, brush bar restricted, broken belt, bad brush bar motor or loose wire on any of the above
Jan 25, 2014 | Dyson DC27 Bagless Upright Vacuum
Hi, i have a panasonic eco max, the brush has stopped going round, the belt is as new and brushes clean.suction good from hose. Any ideas please? thank you
The brush on this model is controlled by the on/carpet/floor switch and will only work in the carpet position. If the suction motor is running then it could be the roller brush motor, but it's more likely to be the microswitch which stops the brush motor when the handle is returned to the upright position.
Dec 03, 2012 | Panasonic Mc-Ul594 Eco Max - Bagless...
Pro hEat will not **** up water from carpet
check the vac motor hose could be clogged? does the vacuum motor turn on? check the vac motor on switch for power using an ohms meter.could have a bad vacuum motor or micro switch.
Jan 26, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Sanitaire vacuum is not picking up well - works ok on floors but not on carpeting
Depending on the model you may have a single or two motor system. If it is not running well in carpet mode but still has suction check to see if the brush for the carpet head is turning. If not look for a red reset switch or spin the brush when the vac is shut off. It it spins freely the belt is either broken or badly stretched and needs replacement.
Sep 05, 2009 | Vacuums
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Apr 18, 2008 | Bissell Vacuums
Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
Aug 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
114 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
