Question about Dyson DC28 Animal Bagless Upright Vacuum
Carpet suction is not working - Dyson DC28 Animal Bagless Upright Vacuum
There are several filters that either need to be cleaned or replaced. Most forget about the filter under the canister. That is the main one for floor suction. More than likely it is clogged and needs to be replaced. http://youtu.be/RCRdUCBobIc
Posted on Oct 11, 2013
Does not work i have every where that dog hair that block still no sucken
Posted on Oct 17, 2013
  • Brent Sansbury Oct 17, 2013
    If you have checked both filters and cleaned or replaced them then you need to make sure there are no blockages in any or the tubes.
    If you still have no suction then make sure the collection cylinder is not blocked with dust. (the little holes inside the container). If you use a wet cloth to clean anything, make sure everything is completely dry before restarting.
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Mar 01, 2015 | Riccar Vacuums
The suction on my dyson is too strong
i don*t know alot about dyson but if it has a thing to raise it up off the floor then that will work
Jan 26, 2013 | Dyson Vacuum Dc 14 Low Reach
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
I have a dyson 07. Vacuum works fine, great suction using the hose. How do I switch to using the carpet vacuum. (I lost my instruction book) Thanks
If this unit has a suction hose built in to the handle, the carpet vacuum should start working after you return the handle hose to the proper position.
Dec 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Dec 29, 2009 | Riccar 8850 Vacuum
I have a u3450 1500w hoover, suction on hose works fine, but carpet suction has never worked, how can i fix this?
There must be a restriction or blockage in the carpet suction pipe. Look at the port where the hose connects to the machine and check for any accumulation of debris or blockage. The same motor drives both suction inlets so it can only be that there is an obstruction.
Nov 02, 2008 | Hoover Vacuums
No suction when carpet cleaning. Also won't stand upright
Its possible that it may be blocked in the foot of the vaccum. try going through your instruction manual to locate details on how to disassemble the suction brush and connecting ducts. If you dont have one then use this link to download it. http://ubermanuals.com/node/1870
Let me know how you got on
Cheers
Jun 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction only works using the hand held mode, there is no suction when try to use on carpet mode,
There must be a clog in either the hose, dirt inland by the brush roll, or bad filters. If you have suction at the end of the hose, then look lower all the way to the brush roll.
Mar 25, 2008 | Vacuums
Dyson DC28 Animal Bagless Upright Vacuum Logo
283 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
