Question about TalkSwitch TS-80 Corded Phone
How do I change the date and time on a talkswitch TS-80 corded phone?
I have a corded model #77519 phone, how do I change the time and date.
The complete user's manual for your phone is available at the following link:
http://www.retrevo.com/d/df/MANUAL000032975.pdf?doc=532906c5a747ab87134404141e9c11c8&ts=1313184836863&rk=0.17208479428095913
Just use your mouse to click on the link which is the highlighted and underlined text above. This will open a new browser page for you automatically and allow you to download the manual.
Here is an excerp from that manual which describes how to set the time and date:
GETTING STARTED
Caller ID Initial Setup:
After the battery installation and telephone line connection the display will show the Set Language screen:
Set Language
1. Press the Review UP or DOWN button to select the desired language.
E=ENGLISH
F=FRENCH
S=SPANISH
2. Once the desired language is selected , press the ERASE button to
confirm selection.
3. Then the display will change to the Set Time / Date screen and the hour icon will be blinking.
Set Time/Date
1. Press the UP or DOWN button to set the current hour.
2. Press the ERASE button to shift to the minute setting.
3. Repeat steps 1 and 2 above to set MINUTE, MONTH and DATE.
4. Once the correct TIME/DATE is shown on the display, press the
ERASE button to end the setting. Then the display will change to
show the normal status.
Changing The Language Mode and TIME/DATE
1. Press and hold the ERASE button then press UP button.
2. Then follow the steps described above.
Good luck, I hope this was helpful.
Joe.
Aug 12, 2011 | Northwestern Bell 77519 Corded Phone...
We have a Talkswitch system at our office. My Talkswitch 480i now seems to has lost its brains. When I power it down now, it does not seem to talk to the switch to obtain its configuration. It always...
The problem would seem like the phone is not finding the TalkSwitch system, or the configuration file for the phone does not exist. There are usually only 3 things that can cause this issue to occur:
1. Verify that the IP address for the TFTP Server, this must be your current public IP address. This can be found in the phone's menu under Networking -> TFTP Server -> Primary TFTP Server
2. Ensure that port 69 is open in the firewall at the TalkSwitch's side. Run the TS firewall test to confirm that it passes.
3. Confirm that you have the correct MAC address entered in for the Extension in the TalkSwitch software
Jan 05, 2011 | TalkSwitch TS-480i
If someone is using a headset with a TS-200 multiline system, will incoming calls be picked up by the phone in headset mode first?
That should be a configurable setting. Speaker, Headset, Speaker then headset or Headset then Speaker.
Jun 25, 2010 | TalkSwitch TS-200 Phone
Is there anyway to change the name that is
It's part of the phone system, it's software. Find out who controls the phone system and get your name on it.
Nov 25, 2009 | TalkSwitch TS-9133i
How do I access my voice mail remotely? (talkswitch ts200)
Call into the system and when the attendant picks up dial **+(mailbox number or extension number)
Aug 03, 2009 | TalkSwitch TS-200 Phone
Number of Rings Before Pick-up
Log into your Management software.
Go to each phone line.
At the very bottom of the call handling section you should see routing options. Change these setting to the desired number of rings.
Hope this helps you.
Oct 22, 2008 | TalkSwitch TS-480i
Somethings wrong!
Sorry to have to ask all these questions, but they are necessary to try to help figure out what is going on. I need to know what TalkSwitch system model you are using and what version of software it is running. A system serial number is required if I need to contact my distributor. If you could provide the current configuration file on the system, that may help as well.
I am an authorized TalkSwitch Partner and will try to assist you.
Sep 28, 2007 | TalkSwitch TS-400 Phone
TalkSwitch TS-80 Corded Phone Logo
Top TalkSwitch Lands Phones Experts
Are you a TalkSwitch Lands Phone Expert? Answer questions, earn points and help others
