CAN NOT BOOT UP LAPTOP
When i turn my laptop on sometimes it will not boot up at all and other times it will boot up and load fine but then switch itself off or just freeze and then switch off - on th eoccassions it has booted up i have tried a restore but will not stay running long enough to complete so have been unable to check for updates etc etc now it seems to not even stay powered on for more than a few seconds before switching itself off and then back on again
  • 46 Answers
Sounds like you may have an intermittent memory problem try a diagnostic cd like ultimate boot cd other possibilities are bad power supply or motherboard issue.but since you didn't say sometimes when you hit the button nothing happens.i will guess it's not power supply.eliminate.memory cpu hardrive issues first then we'll go from there.
http://www.ultimatebootcd.com/
Posted on Apr 23, 2009
HP Dv5t laptop wont switch on
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 21, 2012 | HP Computers & Internet
My Acer Aspire 1500 laptop wont pass startup.
It seems that your laptop hardware is good and it seems that it is a software issue.
  1. Boot in safe mode: When your laptop start, press the F8 key. then it will ask you which boot device to boot from, browse using the arrow keys and chose something with HDD and press ENTER and then press the F8 key again. Then you will be given a boot option and choose SAFE MODE.
  2. While in SAFE MODE, try to uninstall your newly installed software that might be causing the laptop to hung up.
  3. Also, click Start => Run then type: msconfig.
  4. Go to the Startup Tab and uncheck the many programs that looks not necessary to load while windows is loading. The program like Yahoo Messenger, Skype can be opened manually so uncheck them if present.
  5. Click Apply then OK.
  6. Restart your laptop and see if it helps.
Feb 23, 2010 | Computers & Internet
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
Gateway t 1625 laptop not booting
If u can, try to reformat it, reason i say this simple solution is because u already had the laptop looked at professionally, and due to you're laptop being stuck at the windows screen, i see this happen on HDD swaps a lot. The HDD needs to be repair-formatted or fully reformatted to talk to the new mobo when switched out, try this if all else fails, i personally think giving this simple solution may fix the boot up issue, but do make sure ur friend who looked at your laptop hadn't reset ur C MOS and may of not reconfigured it, this may also be the main cause of boot up troubles so make sure everything looks fine in ur BIOS. Gabriel will have a more proper solution than this but i believe by doing this it may help u bypass ur loading issue
Jun 24, 2009 | Gateway T-1625 Notebook
G620 boot problem
after ur long question the problem is the faulty RAM ... ur RAM is causing all this remove and replace your RAM . ur problem will get solved..
Jun 23, 2009 | E-Machines (308714) Motherboard
Laptop Will not load past the windows loading screen
BOOT UP INTO SAFE MODE AND LET WINDOWS TO TRY AND FIX IF YOU DO NOT DO THIS THEN YOU ARE GOING DESTROY THE MASTER BOOOT SECTOR ON THE HARD DRIVE AND THAN YOU HAVE TO PAY SOME ONE LINKE ME TO REBUILD THE MASTER BOOT RECORD, UNLESS YOU MAY HAVE ALREADY DONE
CANDYMANGANDY
Jan 29, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
IBM Thinkpad R31
It looks like hardware problem.
Nov 08, 2008 | IBM ThinkPad R40 2722 Notebook
Toshiba Satellite M35x-S1142 Turn off problem
Was something new installed. It's failing during the driver load. You can quick fix it, maybe, by booting and pressing the F8 key, then selecting Last Good Configuration (words of that effect). If that does not work, boot with F8 and trace each driver as it loads. The one it stops on is the one you want to deal with. Boot in Safe Mode again and try to fix the problem. Do you have anything showing up under the Question Mark in device drivers? You may need to deal with the problem on that level also. Cheers.
Apr 08, 2008 | Computers & Internet
Boot up problem
press F8 rapidely while booting
choose safe mode
go to My computer->properties->system restore
restore to the last good working restore point
good luck
don't forget to vote
Jan 19, 2008 | Computers & Internet
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
