Question about Acer Computers & Internet
System wizard i recently reformatted my laptop but now i keep getting an error. it says in order to use full functionality of this program i must run system wizard then asks if i want to i click yes and then it tells me i have to restart but i restart and nothing happens it just loops me through the same steps
  • megan_n_donn
    megan_n_donn Oct 11, 2013
    i think i should further specify.. everything works but my fingerprint scanner which is the whole reason i want this fixed
  • megan_n_donn
    also its an acer aspire 8929g i dont no if that helps
    Sergeant:
  • 252 Answers
Try to repair the window again.
Posted on Oct 12, 2013
Testimonial: "how so?"
My laptop is very slow bunged up with junk
Run Advanced System Care from iobit.com. It is free and it works!
Nov 10, 2013 | Computers & Internet
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
I have used trutech/camarades webcam for years its version 2.2 which is the best version. When i try to open the program i'm getting an access violation.
I need more info... What is the operating system installed on your computer?
Have you every run Windows update recently?
Is this the first time you install this software?
Give me the brief description about your system's configuration.
There must be some error code/s with the "Access violation/denied...." if so, give me the full error message, there are several similar errors with similar codes, but the fixes and diagnostic measures are different...
Thanks...
Oct 08, 2010 | Computers & Internet
How to reformat my laptop
  1. If you have the recovery cd, you can just pop-in the CD, select the reformat option and the installation process will continue automatically. Some laptop might have a special partition in the drive contains the operating system, drivers, etc. in case you want to reformat your laptop without the CD.
  2. Step 2 If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
  3. Step 3 If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
  4. Step 4 After the reformatting process finished and you have installed a new clean OS. Install drivers one by one and restart when it's required. Try to do it in order from basic function -> secondary ex. motherboard, chipset, graphic, sound, modem, networking, etc.
  5. Step 5 Install back all programs that you might need. If you already backup the installation programs or have the installation CDs handy, you can do this pretty fast.
  6. Step 6 Rearrange the look and customize your new operating system, refer to the screenshot you have taken earlier before the reformatting process begin if you want to get the same look and feel.
Jun 26, 2010 | Acer Aspire 5315 Notebook
How do u reformat acer extensa 5620
Step
1If you have the recovery cd, you can just pop-in the CD, select the reformat option and the installation process will continue automatically. Some laptop might have a special partition in the drive contains the operating system, drivers, etc. in case you want to reformat your laptop without the CD.
Step
2If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
Step
3If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
Step
4After the reformatting process finished and you have installed a new clean OS. Install drivers one by one and restart when it's required. Try to do it in order from basic function -> secondary ex. motherboard, chipset, graphic, sound, modem, networking, etc.
Step
5Install back all programs that you might need. If you already backup the installation programs or have the installation CDs handy, you can do this pretty fast.
Step
6Rearrange the look and customize your new operating system, refer to the screenshot you have taken earlier before the reformatting process begin if you want to get the same look and feel.
Jun 01, 2010 | Acer Extensa 5620-4020 Notebook
How to reformat acer aspire one
Put a Windows XP disk (has to be the full version not an upgrade) into the CD drive and the computer will ask to "press any key to boot from CD". Press a key. Follow the prompts, It is important to delete the partition when asked. Then recreate it. Format the drive with NTFS file system. The setup will go on to reinstall windows automatically.
Now, the only challenge is to reload any software drivers for components Windows does not find automatically. This is a little tricky. Do google search of Acer drivers or go to www.drivers.com.
Also, remember all your software programs need to be re-installed. For example, your Microsoft Office (word, excel, etc). Any games, any virus protection, Quickbooks, etc. The printer software also needs to be re-installed. Hopefully you still have the original disk or if its a Hewlett Packard go to their website.
Aug 15, 2009 | Acer Aspire One PC Notebook
How to reformat the lab top
Instructions
  2. If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
  3. If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
  4. After the reformatting process finished and you have installed a new clean OS. Install drivers one by one and restart when it's required. Try to do it in order from basic function -> secondary ex. motherboard, chipset, graphic, sound, modem, networking, etc.
  5. Install back all programs that you might need. If you already backup the installation programs or have the installation CDs handy, you can do this pretty fast.
  6. Rearrange the look and customize your new operating system, refer to the screenshot you have taken earlier before the reformatting process begin if you want to get the same look and feel.
Do it and reply me.
Dell Inspiron 1525 Blue screen & windows error messages/reformat
Do a recovery first and if you are still getting a blue screen on this 1525 call dell and ask for a replacment do not go any further in trying to repair it yourself as anything you do would just make matters worse if its out of warrenty then the only thing you can do is try:
1. clean the unit if there is any dust
2. try new memory modules
3. run a memory diagnostic on it using windos diagnostics
4. recover the operating system.
I hope you have some good luck with this advice.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
PHRHYC?
To get rid of this completely and get the system back up and running, you will need to reformat the hard drive and install a new operating system. Be sure to do a full NTFS format to ensure that complete removal of this bug, not the quick format.
Aug 28, 2008 | IBM ThinkPad T21 2648 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
