Question about Garden
I have a 49cc apc Harley mini chopper. I just put a brand new carb to try and get it running. Clean tank clean gas tank filter clear lines. I have spark to the plug and fuel to the primer bulb. I can not get any response what do ever. A list of trouble shooting ideas would be great! Also if you take the spark plug out and cover the hole with your finger it does have compression. How much it should have I'm not sure
  • 7,482 Answers
Hi prestonaturn
Here are a few pointers you can check...hope it helps
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets, fuel passages or a diaphram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the bike is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Bud
Posted on Oct 11, 2013
  • prestonaturn Oct 11, 2013
    Curtis thank you for your response. I have put a brand new carb on this chopper and I have fuel to the primer bulb. I also have spark and compression but as I pull and pull the rope I get absolutely no response. No back pressure no bogging, no nothing but turning over. I have checked and cleaned the gas tank, lines and filter. I am just stumped on what else to look for
4 Suggested Answers
  • 1702 Answers
SOURCE: My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Posted on Jun 13, 2011
Testimonial: "Thank you. I had to merely add more gas to tank & bulb siphoned fine. Changed the plug and bingo! It started & runs great. "
  • 150 Answers
SOURCE: runs on starting fluid, not
Try spraying a little gas where you spray starter fluid. If it runs you may have to install diaphram kit. If it has a choke can get around primer not working.
Posted on Oct 01, 2010
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
I need to know the size of the center hole on a 19 tooth transmission sprocket for an apc mini chopper Thanks
Why do you need to know the size of the centre hole. That one look in great condition. The size is the size of the shaft it fits on, so you measure the narrower distance, which is between the sprocket tooth that is under the middle of your thumb nail, to the second tooth past your index finger. All this links have info.
  • mini chopper sprockets ' eBay www.ebay.com > Search > mini chopper sprockets Refine your search for mini chopper sprockets. ... Mini Chopper Pocket Bike Parts 19 Tooth Front ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ...
  • mini chopper sprocket in Parts & Accessories ' eBay www.ebay.com > Search > mini chopper sprocket Find mini chopper sprocket from a vast selection of ... Mini Chopper Pocket Bike Parts 19 Tooth Front Chain Sprocket ... APC MINI CHOPPER 48" THROTTLE CABLE ...
  • I need to know the size of the center hole on a 19 tooth ... www.fixya.com > Forum > Motorcycles > APC ... a 19 tooth transmission sprocket for an apc mini ... on a 19 tooth transmission sprocket for an apc ... rear 28 tooth sprocket for an apc mini chopper.I ...
  • Mini Chopper Sprocket and Clutch - DIY Go Karts www.diygokarts.com/chopper-plans/drive-assembly.html ... a torque converter can be used which effectively gives the project an automatic transmission. ... mini-chopper's clutch ... tooth #35 pitch. This size sprocket ...
  • mini chopper parts ' eBay www.ebay.ca > Search > mini chopper parts mini chopper parts 352 listings. ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ... #428 Chain 17 Tooth 14mm Pitch Sprocket Part Gear Go Kart ...
  • Sprockets - PartsForScooters www.partsforscooters.com/Pocket-Bikes-Parts/Pocket-Bikes-Sprocket Mini-Chopper Parts; ... 127-19 . Stock 6 Tooth Front Sprocket with M10x1.00 thread size for 47 and 49cc 2-stroke cag style pocket bikes and mini-quads.
  • Mini Chopper Parts ' Mini Bike Parts ' We Ship https://www.gokartsupply.com/chopper.htm Home >> Parts Catalog> Mini-Chopper Parts. Parts For Mini Choppers Seats - Hand Controls - Fenders. ... SPROCKET 60T #35. 7-1/4" 28.50. 04-470. SPROCKET 72T ...
  • Electra / APC Mini Chopper w 49cc PS engine - Pocket Bike ... www.pocketbikeplanet.com/showthread.php?t=84442
    • 20 POSTS
    • FIRST POST: 2014-06-29
    2014-07-26 · Electra / APC Mini Chopper w 49cc PS engine Mini Choppers. ... Sounds like you got a transmission with slag on the internal gears ... do a search as mini chopper parts.
  • mini chopper bike ' eBay www.ebay.ca > Search > mini chopper bike Find great deals on eBay for mini chopper bike and ... 43CC 49CC APC MINI CHOPPER MINI BIKE MONKEY ... 17 tooth sprocket gear Pocket Bike Mini Chopper ...
  • Rawge's Mini Chopper Information Site - Gearing and Sprockets www.rawge.bravepages.com/minichoppers/speedo.htm Rawge's Mini Choppers ... The Simple Mini Chopper Drive ... you can expect from your mini chopper, given the size of the sprocket on your ...
  • Pagination
  • Apr 08, 2016 | APC Motorcycles
    Hi I need to purchase a 19 tooth drive sprocket and rear 28 tooth sprocket for an apc mini chopper.I also need 5ft of #410 chain
    Hi, Paul for this situation I would call my local dealer or reputable shop's service/parts department (Pep Boys) and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
    APC Mini Chopper Parts Accessories eBay
    Mini Chopper PartsThere are232products
    Mini Chopper Bike Parts 33cc 43cc 49cc Stock Replacement
    apc mini chopper pepboys
    Apr 07, 2016 | APC Motorcycles
    What is the gear size on the motor and chain size on a 43 cc mini chopper?
    Hi Paul the front sprocket is 19 tooth and chain size is # 410 don't know how many links though. For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
    http://www.ebay.com/bhp/apc-mini-chopper
    Chain too loose
    http://www.aliexpress.com/49cc-2-stroke-mini-chopper_reviews.html
    APC Mini Chopper Questions
    Apr 06, 2016 | APC Motorcycles
    How do I find a wire diagram for a 4949cc mini choppers ga-643f
    Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
    http://www.tootoo.com/idetail/49cc-mini-chopper-with-two-strokes-ga-643f_24495635_721073_6878978_16262765
    49cc mini chopper wiring diagram Google Search
    Download 49cc mini chopper wiring diagram
    APC Mini Chopper Key Switch
    Dec 15, 2015 | Motorcycles
    What would stop my 49cc mini chopper motor from starting?
    Put the choke halfway in the middle and try pulling while twisting the accelerater
    Oct 16, 2013 | Garden
    What could be causing my 49cc mini chopper motor from starting?
    If its a brand new carb and you have compression and spark most likely the problem is the idle mixture screw is turned in too far or turned out too far I think the proper setting is 1and a half turns out from being lightly seated .if that doesn't work check your spark plug for proper gap or clean it
    Oct 12, 2013 | Garden
    Engine stalls out after 15 to 20 seconds of run time
    get a carb kit new fuel lines.new fuel filter, air filter clean the tank and carb install new filters and fuel lines and you should be good... or you could first try pouring the gas in a clean clear container and see if you have water sitting in the bottom, then you could get a way w changing the gas you might have to let it stall out on you a couple times before you get rid of the water in the lines and carb run it on a littl less than 3/4 choke.
    Jul 02, 2010 | Mantis 2-Cycle Tiller
    Garden Logo
    147 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
