Question about Acer NX.M89AA.002 - Aspire V5-131-B8474G50akk 11.6 LED Notebook
It works so poor and slowly..always a screen appear to ask me Fix errors...I don't know what to do
    Sergeant:
  • 252 Answers
Need to repair the window.
Posted on Oct 12, 2013
How do I fix a HP Pavilion entertainment PC when it says its Non core? I can't install no new windows ??
ok w8.1
laptop or desktop?
what is your service tag info. less serial
see 1 example here, its on bottom of Laptop
or on outercase desktop, look.
Mar 18, 2017 | HP Computers & Internet
Troube code: C-E004. Error message: an internal error has occured. Turn OFF and ON the main switch. If the troube code appears again contact your service representative.
Find a local servicing dealer and ask what the error code means...
If they don't know or won't tell you, go somewhere else, even if that means the factory,
When you find someone who does know what it means and is happy to tell you, ask how much it will cost to fix...
Jul 25, 2016 | Office Equipment & Supplies
Canon mp770 could not print
Please check if there is some error code appear in printer display. If you don't understand japanese then find someone who understand. No one can troubleshoot it without knowing the error message :).
Find the printer solution at Printer Clinic
OR
Download Service Manual
Sep 23, 2012 | Office Equipment & Supplies
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
Hi, my problem is: SOmetimes, my monitor have bad color, it doesent looks like usualy, it looks bad, the color is different, bad, it appears in a grey fundal, transparency, i donw know what is the problem,...
Check the video connection cable. Unplug it from monitor and computer, and fix it again, completely screwing it. When there is poor color, try to move/slowly pull the cable on both sides. The best solution to try is to install a completely new video cable.
Hope it helps. Dan
Sep 22, 2011 | HP Compaq 1720 17" LCD Monitor
My GPS was working fine until today when I started the car, GPS screen didn't show up at all. I don't know why it suddenly doesn't work.
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..keep reading.
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Please Support Our Troops
Sep 06, 2011 | Magellan Maestro 4040 GPS Receiver
Using XML Notepad 2007 on a Dell laptop running Windows 7 Pro with 8Gb of RAM. The application runs extremely slowly and sometimes never locates a line I am looking for from the error list or from a find....
Hello and welcome to fixya.
This post/link might be what you were looking for. It appears that this MS tool has apparently some issues. Unless this tool provides some special functionality (like Visual Studio collaboration/integration) that other editors don't I reccomend to use these very good (AND FREE) alternatives:
1. Notepad++ here. (PHP,TXT,XML, all-around editor can use regex to search any file)
2. XmlPad here.
Let me know if this post helped you at all.
**Don't forget to rate this solution**
Thanks.
Regards from FixYa.com
Mar 14, 2011 | Microsoft XML Notepad 2007
My gps screen says battery level critically low. Screen on top of that says Load error. Load button's bitmap fail. Touch screen will not respond
the following advice pertains to the following magellan gps systems.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
Bill
Nov 06, 2010 | Magellan Maestro 4040 GPS Receiver
Error in registry
The easy way is to make windows repair itself, this can be done by starting your pc from the windows cd, then when the blue screen appears with 3 options,
..install windows,...repaire,...quite ..F3,
press enter for installation, then F8 to accept, then windows setup will search for installed OS and then asked you to press R to repair it, from this point you can press R and wait while installer delete windows system files the reinstall them without loosing your installed programs.
Dec 10, 2008 | Computers & Internet
Rca p52937sg
Hi, your vertical section is beginning to fail, from your description you have a few electrolytic capacitors that are beginning to go bad, the correct term is they are "leaky", the set can be fixed easily by a tech, not so easy for a layperson because you don`t have the service manual or a capacitor analyzer. NOT an expensive fix, tech will have to remove board, unsolder some caps, check them and replace the bad ones, do a little touch up solder work and set is good as new, any questions? feel free to ask away, if not Happy Holidays, BMW Rider
Dec 08, 2007 | RCA P52937 52" Rear Projection Television
Acer NX.M89AA.002 - Aspire V5-131-B8474G50akk 11.6 LED Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
