Install a electronic spark on lp gas after pilot LITE IS REMOVED
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
Bruce I am not sure I understand or you wanting to remove a pilot light you have and install a electronic spark and pilot
or do you want o remove the pilot ,install the spark and reinstall the pilot
You can't have an electronic spark igniter and no pilot light
Posted on Oct 20, 2013
jgwhomeequip
  • 1902 Answers
SOURCE: pilot light goes out when turning on the thermostat
Check your thermocoupling to make sure that it is sensing flame. You can tell if it is good or bad by the white on the tip of the flame sensor. The other problem would be a blocked or closed flue pipe. Make sure that the cap is not smashed down on the pipe on your roof
Posted on Feb 13, 2009
  • 5 Answers
SOURCE: switching from natural gas to lp gas
Get in contact with the appliance manfacter, ask them for a conversion kit and if it can be done they will send you out all you need. Obviously there will be a charge.
Posted on Jan 01, 2010
  • 15 Answers
SOURCE: Gas Furnace - residential -found furnace off - pilot light off -
check ur venting first make sure its not plugged
Posted on Jan 02, 2010
  • 101 Answers
SOURCE: VN18TB PILOT LITE GOES OUT STAY LITE TILL
Sounds like a weak thermocouple. With the extra heat of the main burner running it can keep the pilot solenoid open...without it it fails shut. Try replacing the thermocouple. (small rod the pilot flame burns against with a skinny copper tube going to gas valve).
Posted on Jan 04, 2010
SOURCE: Laars Lite 2 Coversion to LP Gas
The burner and pilot orfices will have to be changed. Also the gas valve has to be set up with a spring kit for lp gas. I purchased the orifices from Laar. and the Gas valve kit on E-bay for a honeywell valve.Laars wanted to sell a new gas valve but that's not necessary.
Posted on Jan 23, 2010
Need to turn gas pilot on
Stove in ? has electronic pilot so there is nothing to turn on
top burners should have spark and oven has a glow
if the burners not lite do you here a clicking sound no clicking spark box is bad
oven not lite need glow
price of glow $40 price of spark box $60
Nov 02, 2014 | Hotpoint Kitchen Ranges
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Convert Laars lite model lg125n to LP gas
That involves changing out the complete burner tray including the igniter/pilot assembly, burners and the gas valve. It runs deep into the cost of a new heater, (well over $1000, not installed).
Nov 27, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a ProCom Ventless Fireplace. LP Sometime
that shouldnt matter u probably have a runner tube where the gas runs from burner to burner sometimes they get clogged or spiders can build webs in them ur best bet is to turn the gas off take apart and clean tat should solve ur problem
Feb 26, 2010 | Procom ML300TBA Heater
Hi you will need a gas fitter to do this and set it up
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Problem with pilot shuting after heater thermostat cycles off
It could be a few things:
1.Not enough fresh air or the unit is too large for the room it is installed.
(Try to open a window)
2. It could be low gas pressure. This can happen it your LP tank is low or something is wrong with the line.
(Call your gas or LP company)
3. ODS Pilot may be clogged.
(Use a vaccum cleaner, pressurized air, or a small, soft bristled brush to clean).
If this does not fix the problem you may need to replace the pilot. You can contact them at 800-446-1446 or on-line at www.masterparts.net. I hope this helps!
Jan 01, 2009 | Desa International GWRP26T Infra-Red Wall...
My colman heater pilot lite is on but the main heat does not work
First of all DO NOT try to fix this yourself. Call a qualified repair tech. The pilot valve in your main gas valve is stuck open and will not allow the main valve to open. I repeat DO NOT attempt to repair this yourself. LP gas is not forgiving.
Dec 28, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
