Question about American Standard Home
I have a Cadet 3 toilet with a slow flow when flushed.I just had my sewer lines cleaned and had to pull the toilet. After I reinstalled the toilet, I discovered the slow flow.A toilet snake was used on the toilet before it was pulled. What could be causing my problem?
  • 22 Answers
It could be a venting issue. Check the roof vent for the plumbing system. Perhaps clogged with leaves or other debris causing a blockage in the vent line. You can use a hose up to the roof and flush out the vent line. Another problem may be calcium buildup. CLR , a product available at most hardware and grocery stores will dissolve mineral buildups.
Posted on Nov 11, 2013
  • 171 Answers
SOURCE: Toilet tank is refilling slowly.
Hi AaronYC,
I'm Harvey the Master Plumbe.
Your problem is: Installed a new American Standard Cadet 3 toilet bowl and tank at home. When you turn the water supply on, the tank refills normally and stops normally. After you flush, the refill is very slow. When it refills normally the water comes out from the bottom of the pipe (i.e. the pipe that houses the float cup) and when it is refilling slowly, it comes from the top of the pipe. Sometimes (but not always), you can shut the water supply off and when you turn it back on, the flow of water goes from slow to fast instantly - but you haven't been able to recreate this consistently.
These are the facts. American Standard has been keeping costs down by out sourceing. Their toilets are now built in third world countries and parts are made cheap. They're all doing it. Quality control is pretty good but your toilet came with a bad "ballcock". That's the refill part on the left. Because it's new, if you take the ball **** back to place of purchase they should give you new. If not, they cost less than $ 10.00 and easy to replace.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
  • 14 Answers
SOURCE: Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Posted on Jan 10, 2009
kachbibi1
  • 979 Answers
SOURCE: Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Posted on Jan 28, 2009
whytfang
  • 170 Answers
SOURCE: New American Standard Flowise toilet won't flush
You have a sewer issue....it is entirely possible for other things to cause the toilet to loose water as they drain....but only if there is a sewer problem.....that is why there is an air gap between the toilet and the tank...(the trap) now I have been in this industry 35 years and the jet you speak of is in the bottom of the toilet that directs and forces flow down and out of the bowl as do the many small holes on the underside of the bowl lip ( I suspect ...as I have seen it MANY MANY time in the paste) that your old bowl may have had lots of calcium or lime build up (using lime a away occasionally helps) in the holes under the lip as well as other places...which reduces water flow and there by reduces pressure......but what you are describing is definitely sewer related....other water sources causing water to drain...bubbles...etc..I had a similar problem that occurred about once every 2 years in one of my homes...I had a tree root growing into my sewer line ...it would flush but on occasion...debris would get caught and a good plunging would help...but eventually...(twice) I had to rent a 3/4 inch snake from Time Rental...with a cutter head on it and remove the problem. Now your problem sounds exactly like an air gap problem...in that an overflow or something related is causing a vacuum assist when large amounts of water are drained...(ie...tub...washer...).as this happens the force the water carries and the lack of access to air in the flow causes vacuum "tugs" on other water sources attached to the sewer....take of your clean-out cover (usually in the back of the house and if you see water standing in it ....sewer problem....also you can have someone flush the toilet and eyeball the sewer/overflow...to see how it drains.
I hope this helps....good luck...thank you for rating my effort...the Fang.
Posted on Mar 29, 2009
SOURCE: Kohler 81100 Pressure-Clean Flushometer Toilet
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Posted on Apr 21, 2009
Water ridge toilet manual
Thus if the tank is continuing to drain down through the bowl into the sewer line, the rubber flapper is not seating properly with the flush. These become worn and torn and are easily replaced. Or, even with a new one installed, sometimes they are not adjusted properly to create the appropriate balance between play and pull. Play being the upward connection to the flush handle and pull being the downward draw with the gravity flow of the water. Too much play it won't actually flush or lift properly. Too much pull it does not seat tightly or won't lift up long enough to allow enough water to flow through to flush the toilet...as engineered by the geniuses who designed the toilet. A simple adjustment of the chain links attaching the flapper to the flush handle and perhaps a side to side turn of the cuff so the flapper is aligned to seat properly as it drops should be sufficient. And test, test, test, test, and test again until you're absolutely sure you've got it adjusted correctly. One or two flushes is not sufficient!
Dec 08, 2013 | Plumbing
Cadet 3 toilet smells like pee - NOT a SEWER smell, a urine smell. It's a brand new toilet, installed by our contractor. There's a brand new extra thick wax ring too. The room smells like urine when nobody...
If your contractor supplied the toilet, then it is his/her problem, not yours. If you supplied the toilet, then: take a mirror and examine under the lip of the bowl. How does the glazing look? Are there areas without glaze? If so, these bare areas are a breeding ground for bad odors. You can try a thorough cleaning both inside the bowl and around the outside of the toilet with an amonia cleaning product. If you use amonia, DO NOT use bleach: the two combined create a deadly gas. Whatever you do, do not hang a bleach based product inside the tank: the bleach will eat away at anything rubber inside the tank. There is a bleach product that hangs inside the tank and disperses the bleach directly into the tube that leads to the toilet bowl. This would be OK.
Aug 12, 2013 | American Standard 4021 White Cadet 3...
My brand new toilet american standard round front model cadet 3 tank not fill water
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Jan 11, 2013 | American Standard Cadet 3 Right Height...
Sewer gas smell in bathroom.
Sounds like you have an intermittently blocked vent pipe (the one that goes out through your roof). If there is gas pressure in the downstream sewer line and it can't get up through the vent, it could bubble up through your toilet or sinks. I would get up on the roof with a few jugs of powerful drain cleaner and dump them into your vents. You might also run a few dozen gallons of water down those vents after the drain cleaner has had time to work.
Oct 05, 2012 | Plumbing
When I flush my toilet, the water in the bowl rises all the way to the top like it is going to overflow but stops just short of over flowing. Then it drains out but very LITTLE water stays in the bowl. ...
You have some type of obstruction in your drain. Try a plunger when the toilet is still fairly full. The reason the water level is so low is the toilet was finished filling when the water went all the way down. a714b1a.jpg
If you can't get it open with a plunger, a closet auger works well 7163d19.jpg
Aug 17, 2010 | American Standard Cadet 3 Right Height...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
My Whirlpool Cabrio washer is backing up into and overflowing my toilet every once in a while during the spin cylce. But today, the washer was not running and the toilet overflowed. The toilet is located...
Your problem is not with the washing machine. I suspect that the drain line for your toilet is obstructed further down the line than your snake can reach. If you have a clean out riser to your sewer system, flush the toilet while someone else is watching the flow past the clean out. I would say that renting a sewer line snake at a tool rental like Home Depot would solve your problem. Good luck
Mar 05, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a 3 bath rental. The last tenants were
With the toilet clean, try a large shop vac and see if that will unplug it , I had to do that when my son had flushed a toy and it was stuck. If that wont work you will have to pull the toilet.
Oct 24, 2009 | American Standard 2860.334 Enfield Two...
Mar 27, 2009 | American Standard Colony 2388.012.222...
Home Logo
75 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
