Question about MSI MS-6159 Motherboard
It wont turn on
I switched the motherboards of two close computers and i dont know where the wires to the front go on the connectors for the LEDs and the power button.
    Novelist:
  • 231 Answers
Hi, there will be a row of pins at the front of the mobo,use a torch and if posible a magnifying glass to study them. Along side you will see the markings, pwrsw, hdd, rsw etc. the leads from your case will have similar markings. If the led does not work then just reverse the plugs on the pins. Dont worry if you have things the wrong way around no harm will be done it just wont work. Regards mistyman
Posted on Sep 25, 2007
SOURCE:
Cant find my motherboard pin out
http://www.pcmag.com/article2/0,2817,2388344,00.asp?tab=Specs
With all due respect, you have the manual in front of you now
That is unless you started unplugging wires already, and didn't make notes, drawings, or take photos.
Let's use the Asus Essentio CM1630 motherboard for an example.
Couldn't find a CM1730, but that's OK. We'll use this one for a general example,
http://www.ebay.com/itm/OEM-ASUS-ESSENTIO-CM1630-MOTHERBOARD-61-MIBBJ5-01-TESTED-/181007679725?pt=Motherboards&hash=item2a24e600ed
Put your mouse cursor in the middle. Now move your mouse around, using the Zoom In feature.
If this motherboard were mounted in a computer case, it would be turned 90 degrees to the Right.
Bear that in mind.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Goes by many abbreviated names.
PNL 1, FP1, PANEL1, etc.
(Panel 1, Front Panel 1, Panel 1)
Go to the Top/Right corner of the motherboard photo. To the 6 Blue SATA connectors.
Immediately to the bottom of them, is a white Front Panel header.
Two rows of contact pins sticking up.
You need to make notes, drawings, photo, whatever; of where the wires from the Front Panel, go to each one of those pins.
(Some may not be used)
How to know which wires coming from the Front Panel, are the Power On switch wires, Power On LED light wires, HarDDrive activity LED light wires?
Remove the Front Panel from the computer. If it is Not just a cover, EASE it off just enough to look behind it.
You usually can follow the Harddrive activity LED wires.
Harddrive activity LED is usually AWAY from the Power On switch, and Power On LED light.
There's two wires down.
Now look at where the Power On LED light is. Can you see wires going straight to it?
Two more wires down.
From process of elimination, you now know the last two wires going to the Front Panel, are for the Power On switch.
(The Power On switch, is part of the plastic Power On Button assembly. If you look close at the Power On Button assembly, you can see this)
THAT sir, is the MAIN thing.
I can guide you where the other cables go, as far as power cables, and Harddrive cables, and Optical Drive cables. (CD/DVD drive)
If you have already disconnected the Front Panel wires to Front Panel header on motherboard; you get to play a game(?)
Power Supply plugged into power, use a small flat tipped screwdriver, and touch two pins at a time.
When you get to the two Power On switch wire pins, the Power Supply will come on.
Now it is a process of elimination.
Use an LED with two wires, to find out what the rest of the pins are.
The rest of the contact pins in the Front Panel header.
Grab the HDD LED light, or Power On LED light.
You're getting a new computer case anyway.
Touch two pins, and the LED light blinks?
That's the HarDDrive activity LED light, pins.
LED stays on?
That's the Power On LED light, pins.
Either of those LED's are dim, (When the Harddrive is active, or when the computer is on), switch the wires around.
You have the Positive ( + ) wire mixed up with the Ground ( - ) wire.
Moving on.............
The 6 Blue SATA connectors on the motherboard:
If you look close you will see;
SATA0, SATA1, SATA2, SATA3, SATA4, and SATA5.
Or it may be,
SATA1, SATA2, SATA3, SATA4, SATA5, and SATA6.
The Harddrive plugs into SATA0 or SATA1.
Just depends on what the SATA connector numbering starts with.
The main optical drive, or a single optical drive; plugs into SATA1, or SATA2.
A secondary SATA optical drive will plug into SATA2 or SATA3.
(Look at the SATA numbering above, and you can compare side, by side )
HOWEVER, the beauty of SATA is; that you can plug whatever you want to, in ANY SATA connector on the motherboard; and BIOS will find it.
Plug the Harddrive into SATA 3? No problem.
Plug the optical drive into SATA 0? No problem.
BIOS will find the drive with the Operating System on it.
The Harddrive.
Then BIOS will know the other drive/s are optical drives.
(Make sure in the BIOS Setup utility, that the SATA connector on the motherboard you are using, is Enabled.
Otherwise BIOS will Not see the drive)
What cable from the Harddrive, and optical drive; plugs into those SATA connectors on the motherboard?
A SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening in the SATA data cable connector.
Lines up with an L-shape on the motherboard connector.
One example of a SATA connector on the motherboard is shown.
This one is an Open design. Your SATA connectors on the motherboard, will be a Closed design.
Between a SATA data cable connector, and a SATA power cable connector, the SATA power cable connector is larger in width.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
See the SATA harddrive example?
Note the L-shape is pointing DOWN. It is this way EVERY time.
Now you know which way to turn the SATA data cable's connector, when installing. 'Foot' of L-shape goes Down.
More in a Comment.
Mar 14, 2013 | Computers & Internet
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
Front Panel to Board. Color Matching of Wires where there are no Marked Connectors from the Front Panel ?
You can download the manual for your motherboard from Gigabyte here. This will show you the pinout for the front panel connector. If there are no marked connectors on the wires from the front panel, you'll need to remove the panel and follow the wires back to the switches and LEDs. It's usually not difficult to do this as the panel is normally held on with a few screws or simply snaps onto the case.
Good luck! Hope this has helped you, and thanks for using Fixya!
Jan 31, 2010 | Gigabyte GA-K8VM800M Motherboard
Is It required to connect Tower Front Panel I/O to Motherboard
The only front panel pins you need are for the power switch. Track them from the front panel to the connector and plug them upto the 2 pins for power. Dont worry about polarity it can go either way. The connector may look a little odd but it will work just fine. In the past in that situation I have cut the plastic in such a way I have separated the different connections but its not worth the trouble in my opinion.
May 06, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Need connecton diagram for ASUS P4S-LA motherboard.
if colours don,t match up. your main connectors hdd/pwr/reset remove the front panel on the computer. and check from the switches located on the front panel. or you could use a multimeter and test for continuity. if you have one.
you should have green/white red/white orange/white Or blue white.
Mike @ Compurepair.
Mar 15, 2009 | ASUS P4S800-MX Motherboard
Need to know where all the front connectors go
Well mate every connection that you wanna make you'll fin it in the manual... here is the direct link to download the manual.. it is completely illustrated n is a breeze to set up
http://download.gigabyte.ru/manual/motherboard_manual_8vm533m-rz_e.pdf
Lemme know if this solves anything...
Feb 13, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Jumpers problem
170dd8e.jpg This is a jpg of a modern board. Your board may have more pins. The concept is close. Any difference would be located at the Power led. Your's could be three pins & the speaker could be three pins & neither connector would use the middle hole. I suggest you plug in one connector at a time with a boot up in between. Start with the power switch. Testing is simple, press the case power on button. Pc starts your good no light? Turn the connector around & try again. Next plug in the IDE led. Check for light on power up. Most boards, old & new keep their negetive facing to your right. These negetive wires are colored black & wihte. Positive wires are colored green, blue & red. As long as you do 1 connector at a time you should not have a problem. These are all very low voltage, most just leds. Take your time. It will work out.
Jan 14, 2008 | Matsonic MS8127C (MBMS8127C) Motherboard
How do hook up front panel power switch to motherboard
The simple way is to remove the front panel of the computer trace the wires to the front panel leds, make note of color pair to each led. The using the manual that came with the motherboard locate the schematic for the JFP1 connector on the motherboard, it show's where the leds wires connect to operate. If you have no manual, if you look very closely at the connector you will see where the led wires connect, you may have to use a magnifiying glass and flash light. You cannot damage anything if you accidently place the led wires in the wrong place. If the panel led wires are in a single connector and won't work on the motherboard, you can remove the wires from the connector by using a very small sharp pointed pick to push down the retaining tab on each wire, thus enabling it to be removed from the connector, just be patient. BPCS
Dec 31, 2007 | E-Machines eMachines Desktop PC
Ms-6119 front on/off. reset wires disconected from motherboard
http://stason.org/TULARC/pc/motherboards/M/MICRO-STAR-INTERNATIONAL-CO-LTD-Pentium-II-MS-6119.html
If the leds dont light up rotate the plug 180 degrees.
The above site shows you where to place the plugs.
Nov 28, 2007 | Computers & Internet
Computers & Internet Logo
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
