Question about Onkyo TX-SR605 Receiver
My SR 606 has two issues. First, it takes a long time to switch tv over from normal channels to HD channels. Second, the DVD and Game selections are no longer working. I get a "no signal" message. The VCR outlet works and I have my Roku in it. Any suggestions?
    Problem Solver:
  • 6 Answers
I'll second what dennisae said. I've got a TX-NR708 that had all sorts of video issues after about 6 months of use until I got the HDMI board replaced. This seems to be an issue with this brand over a wide number of models.
Posted on Dec 08, 2013
5 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I have a TX SR
This is one of many reasons I recommend against routing ANY video through a receiver if the TV/ monitor has enough connections for all of the video sources.
Bypass the receiver andsee what happens, then isolate a cause.
Posted on Dec 28, 2010
SOURCE: Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Posted on Jan 18, 2009
  • 5 Answers
SOURCE: Put component signals in to the reciver but get none signals out!
You need to turn off the Display Discovery setting on the XBOX
Posted on Feb 12, 2010
  • 137 Answers
SOURCE: TV not receiving video signal from DVD. Component
This model has a defective hdmi pcb assy. this is a well know defect with this model.If under warrenty have hdmi bd replaced if not the hdmi pcb assy retails around $350.00
Posted on Apr 14, 2010
How hook up dvd player to tv. what channel put tv on to see dvd pitcure
You should be connecting your DVD player to either an HD input or a composite video connection. Most modern TV SHOW will have at least 2 HD connections. On your TV setup menu there should be an HD connection to choose (probably HD-2) You will need to switch your input selection on your TV menu between HD/TV for TV and HD2 for DVD. It's hard to give specific directions without knowing the TV and DVD models.
Oct 27, 2016 | Televison & Video
I have a TX SR 606. I have the unit connected with a HDMI cable to my TV. At times it will take several minutes to get a signal to the TV when I turn on HD format. I am also using HDMI from the DVD player...
Dec 28, 2010 | Onkyo TX-SR606 Receiver
Cannot get full picture on the screen
Hi Mic,
Can't get full picture ?
If this is for running a dvd if it is not a
full screen version of the dvd then you
will not get it.
If it is widescreen addition you will get the
black bars at the top and bottom.
If you can't get full screen in normal mode a
few things could cause this.
One if your running from your "say" direct tv box.
You will need to try your Format button...second
button on the left of the remote.
Second you could try the restore settings on your
tv, it will restore the settings to the manufacturer's
original settings.
Keep in mind that not all tv channels are full screen.
Example: If I watch nfl gameday in HD it is full screen.
If I select the same program but, not in HD the screen
is smaller. thing it goes to a 4:3 aspect ration..
Switch back to HD and it's full screen again.
hope this helps some.
Dec 27, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Hook up
You can by an AV splitter box from dick smith or even k-mart audio section that allows you to plug all your units into it, then leads go to your TV. There is a switch on the box which you flick over depending whether you want to watch a DVD or play your game unit.
The other option is to have a llok at the back of your DVD player. Some have input AV's (the red, white and yellow holes !) where you could plug your game console into. Then you just leave your dvd plugged into your tv as normal. To play your game console you turn on TV and DVD player. Have TV on "AV" channel as well as your DVD player on "AV" channel (may also be your input or component channel.
Hope this helps :)
Feb 24, 2008 | Televison & Video
TV freezes when switching to a digital channel
Issue was with the HD channels only.
Updated the firmware of the TV to ver 2.
Now the TV will stutter for a second when changing to a HD channel but it no longer locks up.
Feb 15, 2008 | Westinghouse SK-26H590D Television
Unable to locat and select the AV channel on new LCD HD TV
Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
Cheers and have a Happy Holiday Season!
Dec 21, 2007 | Televison & Video
Onkyo TX-SR605 Receiver Logo
67 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
