Question about Xerox Office Equipment & Supplies
What does error code 004-350 for xerox workcentre 7345
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 50 Answers
004-350 Marking Device Video Fail
Posted on Oct 12, 2013
    New Friend:
what does error code 004-350 for xerox workcentre - error-code-004-350-xerox-workcentre-l4rl0av5jtcfle1hmed4gyfx-2-0.jpg
Reset
Posted on Nov 20, 2014
4 Suggested Answers
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
goodgold
  • 389 Answers
SOURCE: XEROX WORKCENTRE 5222/5225/5230 A FAULT OR
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
Posted on Sep 13, 2009
Xerox 7345 error 004-361
what is the solution erro code 004 361 Machine docucolour 7345 ?
Dec 09, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html
Jun 23, 2012 | Xerox Workcentre 5225 / Copier, With...
How do I clear fault code 016-311 for workcentre 7345
That error indicates the scanner is not installed. Check the connection from the scanner to the main ess board and reseat if necessary. If cable is damaged, replace with part number 117K38440.
http://www.iteminconline.com/117k38440_117k38440-xerox-workcentre-7425-iit-controller-cable.htm
Mar 12, 2012 | Xerox WorkCentre M128 Copier
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
Hi, In my printer Xerox 7245 display it appears Replace Transfer belt error. So please guide me how to reset value without replacing ETB
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
3,034 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
