Question about Dishwashers
Dish Washer Model 665-13113K701 control panel lights flash on and off dishwasher will not run
  • 18 Answers
SOURCE: I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Posted on Feb 04, 2007
SOURCE: Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
SOURCE: my dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Posted on Dec 14, 2008
  • 6 Answers
SOURCE: Dishwasher KUDC25CH; Control Panel is not working
WASH THE DISHES URESELF U LAZY ****!!! :)
Posted on Oct 17, 2009
  • 25 Answers
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
Posted on Dec 05, 2009
Lights flash on my Frigidaire dish washer model #FFBD2407LW0A when trying run it through a cycle. will not start. When I turn power off and back on the heat lights flah.
Good Morning friend, thanks for your post!
Based off the information you have provided your Frigidaire dishwasher is not starting properly. I would recommend performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience this issue it could mean that your control panel or keypad need to be replaced and I would recommend reaching out to a professional technician for proper diagnosis. Hope this helps. -Matt
Oct 06, 2014 | Frigidaire Dishwashers
Lights flash on my Frigidaire dish washer model #FFBD2407LW0A when trying run it through a cycle. will not start. When I turn power off and back on the heat lights flash.
Thank you for your post, friend!
From what you are describing it sounds like a possible issue with your keypad or control panel. I would recommend performing a power reset on your appliance which you can do by unplugging the power cord or flipping the household circuit breaker off for roughly ten minutes.
If that does not help correct the issue I would suggest seeking assistance from a professional to come out and properly diagnosis your appliance to avoid any unnecessary part purchases. -Matt
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
Dish washer the clean light stays on and the dish washer wont run
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Dishwashers
Maytag dishwasher cannot choose cycle on light panel
hello hmm ok so no lights it sounds like your control panel after unplugging your dish washer check the panel for loose wires the panel is the part behind were your buttons are located will have to remove your back cover to access this if that's all good then try your power cord again make sure its not got any loose wires were it attaches into the dish washer have a nice day and good luck let me know if you find anything.
Mar 19, 2009 | Maytag MDB9600A Jetclean II Built-in...
My dishwasher model adp 941 won't start - start led flashes
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Ariston dish washer model ll64xaus Lights 3&4 flashing and unit wont start
Hi pedretti,
I'm Harvey the Master Plumber.
Your problem is: Ariston dish washer model ll64xaus
Try resetting the d/w. Just turn off the curcuit breaker for ten minutes. Sometimes the control board needs to be reset. If this persists you may have to replace the board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Dishwashers
Dishwashers Logo
14 people viewed this question
Top Dishwashers Experts
