Question about Hardware & Accessories
I need instructions sheet for woods 5007? please help!!
    Guru:
  • 154 Answers
Do you mean the Woods 50007 Indoor Digital Timer? If so you can find the online manual here: http://waterheatertimer.org/pdf/Woods-50007_Instruction-manual.pdf
You can also find it on Amazon if you need to replace it: http://www.amazon.com/dp/B005WQIDHY/?tag=waterheaterti-20
Posted on Oct 11, 2013
2 Suggested Answers
SOURCE: I need the instruction sheet
Here is the manual for Woods TD2200
http://waterheatertimer.org/pdf/Woods-49377-TD2200.pdf
Plug in timer.
Let rechargeable battery charge.
Once battery is charged, you can remove timer from plug so programming is easy.
If battery will not charge, then timer is no good.
Posted on Oct 24, 2010
Can I make a homemade light box? Is it difficult?
Yes you can, and it is not that difficult. All you need is a sheet of plastic cut into a square or rectangle shape at whatever size you decide to make the box, a sheet of wood at the same size as the plastic sheet, some wood for the sides of the box, and some bulbs. Make sure the wood for the sides is big enough to fit the light bulbs inside the box, put it together, and you have your light box.
Feb 19, 2013 | Crafts & Hobbies
Can the plastic sheet under the walking belt be purchased . My belt is making a "squealing" noise as it is rubbing off the plastic sheet,which has become "pitted" and worn,This plastic...
dear
we named this sheet deck and it is not plastic but it is wood coated MDF you can measure it and buy any wood shop.
we would be glad help you by smartphon contact us 00989195116738
Sep 10, 2011 | Proform 790T Treadmill
Instructions for setting the timer Lost the instructions sheet
You posted under Woods 59377 timer.
The manual has more words than allowed for free answer, so I cannot copy-paste contents here. If manual is confusing, add a comment with specific question.
Open following link to identify timer for sure:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
59377 timer manual:
http://waterheatertimer.org/pdf/Woods-59377.pdf
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 09, 2011 | Woods Industries 59377 Indoor Digital...
I lost the instruction sheet on how to program this timer can anybody help
You posted next to photo that looks like the Woods 59403
Confirm that this is your timer on following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Several brands sell same timer
If this is not your timer, then add a comment with description of timer and buttons.
I have extensive files on timers, and can probably identify your timer.
Woods 59403 manual:
http://waterheatertimer.org/pdf/Woods-59403.pdf
You can also take advantage of fixya phone service.
Expert will walk you through the steps for a price.
Dec 25, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
I need the instruction sheet for the Woods indoor timer TD2200
Plug in timer.
Oct 24, 2010 | Sylvania SA130 Digital Lamp Timer
Need help setting amp right
volfenhag's are cheap. you get what you pay for. that is the german equiv. to pyramid or kraco.
Jul 10, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
Philips tv model 21 pt 5007/69 circuit manuel
my tv control panel is locked.there is only on screen av1.it is not changed.
Jan 19, 2010 | Philips Televison & Video
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Woods Digital Timer TD 2200
See this website for links to instruction sheets in PDF format for Woods US timers:
http://www.woods.com/us-timer-instructions.asp
Mar 25, 2008 | Sylvania SA130 Digital Lamp Timer
Hardware & Accessories Logo
751 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
