Question about Keurig Platinum B70 Coffee Maker
Water didn't heat well in coffe mashine - Keurig Platinum B70 Coffee Maker
  • 1,511 Answers
Take it back: Needs a new Heater.
Posted on Jan 30, 2014
Mashine fills with water
check the program dial or settings. Put the machine off. then the water slot should close. If it does not close it is defect and you should ask a tech to replace it, or buy a new machine.
Mar 24, 2015 | Washing Machines
I Just bought a Saeco Intelia Focus espresso machine. I made coffe with 3 different coffe brands. Very good ones. And I became very disapointed when I try the results. Every time the espresso was way too...
Use less coffe , you are using too much , reduce the amout you are using . Presto . Also use homogenized milk , not skim , or fat free . Also use the water vapour to heat the cup before you make coffe , capuchino , caffe-latte, mocachino , espresso etc .
Oct 28, 2013 | Saeco Intelia Focus Automatic Espresso...
I need the user manual
Dear friend: I bought mine in 1996 in Orlando. The user manual was so simple with some b/w pictures.
1.- Heat the water.
2.- Over one cup place the thin filter that match perfect and is the bigger one of two elements supplied.
3.- Over the thin filter place the coffe deposit the one that have small holes at the bottom.
4.- Fill the deposit it with coffe for one cup and fill over with hot water slowly from one cup trying not to overflow.
5.- Wait untill the water flows down and your cup of coffe is ready.
6.- For another cup repeat this procedure.
Is a bit long but you can enjoy a room coffe for two.
Its what my experience was. Excelent when you don't find where to boil a cup of water. Now mine machine burns suddenly the heater and I am trying to find the replacement part, but probably should be and adaptation of it.
Good luck. The manual is not much than what I told. Not much manufacturer info. A pitty for a well designed help machine.
Claudio.
Apr 03, 2013 | Franzus TJ-10 Coffee Maker
Delonghi EC850 coffe mashine red light are flashing
I have a Delonghi Figaro and the red led flashing means:
The unit has run enough times to likely be scaled, this is a reminder to run weak acid (vinegar or citric acid) through to descale. Then rinse twice with clean water.
Scale will slow the brewing process so if it's brewing slowly you should do this regardless of the LED.
The LED can be reset by pushing <Prog.> and <On.> at the same time.
Of course, none of this is in the manual.
Sep 14, 2012 | Coffee Makers & Espresso Machines
Just picked up a new Franzus TJ-10 Coffee Maker at a garage sale, but it has no instructions with it. Can you please tell me just how to operate it. Appreciatively, Vincent
1.- Heat the water.
Claudio.
Aug 07, 2011 | Franzus TJ-10 Coffee Maker
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
The hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Dec 30, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Feb 13, 2009 | Bunn Coffee Makers & Espresso Machines
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Keurig Platinum B70 Coffee Maker Logo
29 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
