Question about Bosch AquaStar 2400ES-NG
Getting an F7 error that won't clear. From what I found, this indicates Ionization is on standby. What does that mean? What do I need to do? Thanks!
  • Marsha Harman
    Marsha Harman Oct 11, 2013
    Nevermind - this is what I found out for myself. The error is basically a "false flame" reading. It indicates the heater thinks it is sensing flame while the heater is in standby mode. It could be caused by a loose connection to the flame ionization rod, so the first thing to do is to verify that the thinner wire leading from the control unit is securely connected to the flame sensor located on the lower front of the heat exchanger. It could also indicate that the flame ionization rod or control unit is damaged.
    Top Expert:
  • Bosch Master
  • 12,223 Answers
You must read your owner manual read the troubleshooting section, and if the problem persist, get the website with your supplier and connect via ONLINE chat with technical personal in order to Help you and fix it.
God bless you
Posted on Oct 12, 2013
I am getting a C2 11 problem error on my Rheem tankless water heater, What that mean?
Just how much did you investigate this on the internet before asking here? I Googled " Rheem C2 tankless water heater" and found http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html. Look under Error Codes. Code 11 refer to gas supply/ignition. If you don't know much about tankles water heaters or gas ignition, call a Rheem Tech.
Dec 13, 2014 | Rheem Water Heaters
I have a whirlpool cabrio washer for a while now here and there i was pulling out soaking wet clothes.and ofcourse my warranty ran out yesterday and now it will not start any cycle all its does is sense...
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Here is a list for the errors.
Post back your results.
Sep 14, 2013 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Water is way too hot. Five year old GWH2400E NG is giving error code EC: Ionization failure during operation. set point temperature = 106, inlet water temp = 88, outlet water temp = 171, water flow = 12,...
Before calling service technician who has service manual and can test which part has failed, open following links for troubleshooting resources including steps below and phone number for Bosch:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ETechSupport/Troubleshooting/tabid/1131/Default.aspx
Clean inlet filter
Check all faucets for clear pathway
This unit does not work with preheated water (solar assisted)
Incoming water above 70 degrees, avoid restricted faucets
Check that both temperature sensors are making contact and firmly mounted on respective cold and hot pipes.
Descale heat exchanger
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G2-13_Descaling.pdf
Aug 16, 2011 | Bosch AquaStar 2400ES-NG
It often flashes ea or af and doesnt want to light
Before calling service technician, open following links for troubleshoot resources including common error codes, Bosch contact information, link to service manuals, and possible product manual
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Call Bosch 800-642-3111
Multiple error codes can mean PC board failure.
AF might be A9, but not sure.
EA is 'no flame ionization detected with water flow'
  1. Verify that all manual gas shut off valves are open.
  2. Check gas type.
  3. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater.
  4. Check three wire connections to ignition group on the lower front of the heat exchanger are secure.
  5. Check gas pressure.
  6. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod.
  7. Check that the minimum power fan speed has been adjusted to the proper value.
  8. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Aug 11, 2011 | Bosch AquaStar 2400ES-NG
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Jul 18, 2011 | Water Heaters
Working on a N1321-ASME unit installed in a Taco Bell. Getting error code 21. Unit gas pressure is at 8.5wc and manifold pressure spikes to 2 when it come on but unable to see what it remains at because...
I recently had a similar problem with my N-132M-ASME heater. The unit would come on, then shut down and flash Error Code 21. According to the owners manual, that code indicates the unit is not getting enough air. I tried vacuuming the unit, blowing it our with air and checking to be sure the exhaust lines were clear. Nothing helped. A service technician came out and recommended I descale the unit and clean the burner. I did this but the problem did not go away. He also suggested I replace the Burner Sensor. It's not an expensive part, around $20. I ordered the part and have not had a problem since I installed it. Hope this helps.
Jul 09, 2011 | Noritz Commerical Tankless Water Heater...
I keep getting EC on the display, why does it keep doing this
EC - Ionization failure during operation
Check gas type.
Check venting specifications are met. Improper venting may cause unstable burner flames and loss of flame ionization.
Check gas pressure.
Check and adjust CO2 readings.
Mar 02, 2011 | Bosch & Tankless LP Hot Water Heater
Getting error code 16. what does it mean and what
a 16 error code is typically caused by scale formation. I'd recommend performing a descale on the heater.
Mar 06, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
250sx quit working. Gas o.k. water flow good, throws ea code after 3 start attempts. 1. where is the ionization electrode, and is the fan supposed to come on before ignition? Fan comes on afterea code....
The gas pressure must be increased at the regulator from 9 inches of water column to about 12.5-13 inches of water column. The CO2 levels need to be adjusted for each installation. The air intake MUST come from outside the same wall as the exhaust. I have never seen any manufactures tankless unit installed properly. Plumbers do not read the manual.
Jan 24, 2010 | Bosch & Tankless LP Hot Water Heater
Britony Combi se 80 boiler
Steel wool is the way to clean. Hope this helps
Oct 18, 2009 | Water Heaters
Bosch AquaStar 2400ES-NG  Logo
90 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
