Zenith TV H25C39Y "Concierge TV" and accessing it's On-Screen Menu / I don't have a "Installers Remote" to reengage the hotel locked front panel controls, so that I can then get access to the basic on-screen menu and adjust the colors and brightness. Is there another way around to unlock the front panel or simply get to the on-screen menu without having to purchase the "Installers Remote?
4 Suggested Answers
SOURCE: No Remote - Need to access Menu
We had the same problem - this worked for us:
1. Unplug TV
2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen)
3. Press Channel up and Chanel down at same time. (Access to menu screen)
4. Use Volume up and Volume down to switch between menu options. We finally found the EZ set up screen.
Somehow in the process we muted the TV and are now working on getting the sound back. :)
Good luck to you!
Posted on Oct 05, 2008
SOURCE: Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Posted on Mar 22, 2009
andy4254
  • 226 Answers
SOURCE: RCA XS J25330BL cannot access full setup menu
Your best solution is to get rid of that crappy TV! Having an old tube Tv really makes the rooms look bad.
Posted on Jul 01, 2011
Can I do a Factory default reset on a Zenith Concierge Series H2530Y7 Model Television without the remote control?
ZENITH SC652 Concierge Commercial TV Remote Control buy a master remote then,
  • Press the "Power" button on the Installer's remote control to turn on the TV.
  • 2 Press and hold down the "Menu" button on the remote for about six seconds until the menu disappears.
  • 3 Press the "9," "8," "7," "6" and "CC" buttons in succession. This resets the TV to factory default settings
  • Read more : http://www.ehow.com/how_7393497_reset-zenith-concierge-television.html
    Apr 24, 2015 | Zenith Televison & Video
    Zenith concierge code
    The Hotel sets use a special remote--only way to get one is via the Zenith division of LG. Not cheap and likely why someone got rid of the set.
    May 29, 2012 | Zenith Televison & Video
    How to set dish remote for a zenith concierge tv
    See previous answers for duplicates of this question you posted.
    We have a zenith concierge tv that was donated to a group home. WE have tried programming it so that the cable tv stations can be used but it has a lock on the auto program and I can't figure out how to...
    You have to purchase the master remote from Zenith or a hotel supply company. This is the only way to gain access to programming the concierge. The remote is currently $24.99.
    Jan 22, 2009 | Televison & Video
    I cannot reset the channels on my TV. It is the Concierge TV from a hotel. Will I need to buy a Zenith Remote from the store to do the channel programming. It says it is locked
    You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
    Dec 13, 2008 | Zenith C27A24T 27" TV
    My tv wont let me auto program the channels
    if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
    Zenith TV not programmed for home purpose
    If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
    I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
    To go to installer menu (different from regular menu):
    - Hold MENU for 8 seconds.
    - Press 9, 8, 7, 6 and ENTER in the sequence.
    You should be in the installer menu now. There should be a line that looks something like this:
    03 VERT POS 13
    Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
    CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
    START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
    You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
    I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
    May 26, 2008 | Zenith SC652 Remote Control
    Zenith Concierge hotel tv wont work with my xbox 360
    I doubt the TV even has a tuner if it is designed for a hotel. It may be a "dumb" receiver, nothing else. Do to channel 2 and then press the down arrow for channel, does it flip to 138 or AV1?
    Mar 19, 2008 | Zenith C27A24T 27" TV
    Zenith h32h38dt 32
    The "H" model Zenith TVs are hotel/motel sets designed that
    a roomer cannot access the menu feature. Your best bet would
    be to purchase a name brand universal remote which has the
    menu button feature or order an original Zenith master remote
    which would not require programming. Once you have a workable
    remote which will allow you to access the on-screen menus you
    should be able to program the channels.
    Hope this helps,
    CaseyBee
    Feb 27, 2008 | Televison & Video
    Televison & Video Logo
    23 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
