Question about Vacuums
Not spraying water - Vacuums
    Sergeant:
    Champion:
  • Vacuums Expert
  • 357 Answers
Is that a good thing or a bad thing ? Maybe ask your doctor
Posted on Oct 21, 2013
My rug doctor will not spray out water
check your spray jets are not blocked but also check your small pump is working & operating that spray the water out of the nozzles
Sep 01, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
Hoover floormate deluxe doesn't spray water
Fill tank with water.
Ensure the spray nozzle is not clogged from previous use. Refer to the manual for maintenance of the spray nozzle. Check YouTube for videos for this model. Contact Hoover website for support.
Aug 14, 2014 | Vacuums
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
I have 2 bissell pro x2's that are now both not spraying water
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! d
Jul 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat 9500 won't spray water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ukyr
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat does not spray water along cleaning brush. Seems to spray just down either side only.
Are the brushes turning? If not then that could be your problem. If they are, check the spray nozzles, they may be partially clogged. Try water a mix of vinegar and water thru it to see if it will unlog your kines and spray nozzles.
May 06, 2008 | Vacuums
Won't spray
your pump is bad.i have one doing the same thing.everything works fine except it won't spray,just dribbles
Aug 03, 2007 | Bissell 1400 Little Green Pro Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
