Question about Samsung RFG299AARS Stainless Steel (285 cu ft) Bottom Freezer Refrigerator French Door
The refridgerator compartment is freezing all the food
The refriderator compartment is frezzing all the food and drinks. replaced the teremoster and the defrost heater element didn't work . Help. no support from Samsung.
  • dan barbus
    dan barbus Oct 12, 2013
    that is the full model # rfg299aars
    Top Expert:
  • Samsung Master
  • 9,472 Answers
What is the complete model number list in the refrigerator section?
Posted on Oct 12, 2013
Food in bottom of refridgerator is freezing
If that is the case you will have set the temperature in that compartment of the fridge too low. Adjust it little by little until the freezing problem is solved because the bottom of the unit will eventually not get to freezing point.
Jan 28, 2016 | Refrigerators
Frigidaire plhs267za is to cold and frezzing the food. what do I check
Good Morning friend, thanks for your post!
From what you have described your Frigidaire refrigerator is too cold and freezing food. I would recommend you check the temperature to make sure it is set to a factory setting of 0 for the freezer and 37 for the fresh food side. You can also check to make sure that there is not food in the freezer blocking the damper from closing. The damper is located near the top of your refrigerator.
Place you hand in the rear of your fresh food compartment to feel if the air is too cold or the damper periodically closes. This could be the cause of your refrigerator freezing your food. If you damper is not working properly you may need to replace it. If your damper appears to be in working order your thermostat or control panel could be the issue. I would suggest having a professional out to perform a diagnosis. If you do not have a professional contact you should visit your manufacturer's website to locate a technician in your area. Good luck. -Matt
Feb 28, 2015 | Frigidaire Refrigerators
Refridgerator compartment freezes all food, setting at 1, however door does not have a good seal.
Must have good seal for proper cycling and air flow. Fix what you know is broke and go from there.
Aug 13, 2011 | Refrigerators
I have a Kenmore side by side mod#59657006600 refridgerator. Everything in the refriderator side is frozen. I suspect somebody did not close the door all the way because this happened once before. so I...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 07, 2011 | Kenmore Side by Side Refrigerator
My fridge doesn't have a freezer compartment in it. However the refridgerator is freezing everything in it no matter what setting i change the thermostat to.
heatman101
Apr 29, 2011 | Whirlpool Refrigerators
Everything is freezing in the refridgerator. The water dispenser will not put out water. We have taken the temperture to 0 then back to 5 and it still will freeze in the regular compartment.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 13, 2011 | GE Refrigerators
My Dometic RM2652 RV Refridgerator is freezing on the bottom portion of the refriderator. I read that there is a recall for my refridgerator. Can you tell me what the problem is.
On the back of the refer are the cooling fins. There you will find a small piece about the size of a dime with a wire attached to each side 2 wires total. Move it down the cooling fin to about 1/2 inch from the bottom of the fins
This should solve your problem
Feb 01, 2010 | Dometic RM2652 Refrigerator
Amana Refridgerator freezes in the refridgerated cavity.
Many Amana refrigerators have something called an auto damper. It has a thermostat coil on the side of it and as the temps get colder the damper door closes. If the thermostat on the side becomes defective then the damper door will remain open or shut. If it remains open the food in the fresh food compartment will get so cold that sections will freeze. If you could send the model number of your Amana I may find a service manual with instructions that tell you how to test by removing and dipping the thermostat into warm or cold water to see if it is working properly. I will be here in and out to my other websites but would be happy to assist you and resolve this problem. Thanks Sea Breeze
Jan 21, 2010 | Refrigerators
Food and drinks freezing in my refrigerator. How do I adjust?
Inside your refrigerator is a control on left side of the panel. Try to adjust there and try to close the dampers near the lower drawer bins. If that don't work change the temp a little higher in the fresh food compartment. But closing the ducts should do the thing. Let me know, Thanks Sea Breeze
#27 below in pic try ajusting the air coming into fresh food compartment.
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Apr 21, 2009 | Estate TS25AFXK Side by Side Refrigerator
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
Samsung RFG299AARS Stainless Steel (285 cu ft) Bottom Freezer Refrigerator French Door Logo
150 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
