Question about RCA Audio Players & Recorders
Carlsbro T150 - RCA Audio Players & Recorders
Palmo T150 wiring diagram
Hi, Ted before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Palmo T150 wiring diagram Google Search
Palmo T150 2009 service manual DOWNLOAD FREE FULLMANUALS COM
Palmo t150 manual
Palmo T150 2011
http://moto.fans/spec/palmo/2009/palmo-t150/index.html
May 18, 2017 | Palmo Motorcycles
Where can I get a handle for a Carlsbro Cobra 90 amp?
It really depends which version handle you need but look through ebay or alibaba for replacement luggage handles as a starting point and find a style that looks like it will fit your amp and then drill down from there.
Oct 05, 2014 | Video Game Consoles & Games
Carlsbro instruction manuals
do you own the amp? then as the owner you should have one.Google it.
May 21, 2014 | Radio Communications
Need a Palmo T150 mirror
E-bay's a good place to start :)
Aug 16, 2012 | 2010 Palmo T150
Connect a mic mixer to a powered mixer
What kind of output does the mini mixer have? If may not have enough to input your Carlsbro PA
Nov 16, 2011 | Radio Communications
Back lighting
Funny, I've got one I've just stopped using because the backlight is too bright, even set at its lowest.
Maybe we could trade ;-)
Is your's out completely, or just very dim?
Jan 22, 2008 | Timex T150 Clock Radio
85 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
