Question about Linksys Computers & Internet
I changed my westell wireless router for a wireless netgear because i moved and changed internet to warner cable but did not realize my I pad was WEP and netgear only supports WPS did not know their was a difference help me please..
  • 26 Answers
To really help I need more info like, Netgear Model # which Ipad and IOS version you have. But for general purposes...IF you have a computer you can to rest the security by logging in to the router. The default address is usually 192.168.1.1 for netgear but it is written on the bottom of the router with the ID and password you need to log in. Post back with the above info if you need more help.
Posted on Oct 11, 2013
dante777
  • 623 Answers
SOURCE: Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Posted on Dec 29, 2008
  • 3 Answers
SOURCE: My Westell USB cable won't connect to my Netgear router!
I like to know how to install my router to my modem westell 7500
Posted on Feb 24, 2009
  • 145 Answers
SOURCE: I have Time Warner Cable for internet and Vontage
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Posted on Apr 09, 2009
redhaze89
  • 854 Answers
SOURCE: PS3 Wireless issues
Network settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet using an Ethernet cable.
1. Connect an Ethernet cable to the PS3™ system.
2. Select (Network Settings) under (Settings) in the home menu.
3. Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
4. Select [Easy].
After you confirm the network configuration, a list of settings will be displayed.
Depending on the network environment , additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
5. Save your settings.
6. Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
7. Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
Internet Connection Settings (wireless connection)
This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1. Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2. Confirm that an Ethernet cable is not connected to the PS3™ system.
3. Select (Network Settings) under (Settings) in the home menu.
4. Select [Internet Connection Settings].
5. Select [Easy].
6. Select [Wireless].
7. Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
8. Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
9. Check the SSID for the access point.
10.Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
11. Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12. Save your settings.
13. Test the connection.
14. Confirm the connection test results.
Internet Connection Settings (advanced settings)
If you are unable to connect to the Internet with basic settings, change your settings as necessary. Adjust each item as necessary for your particular network environment.
1. Select (Network Settings) under (Settings) in the home menu.
2. Select [Internet Connection Settings].
3. Select [Custom].
Adjust each item as necessary for the network environment in use. The items displayed vary depending on the settings you have selected.
Connection Method
Set the method for connecting to the Internet. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Wired Connection
Make a wired connection using an Ethernet cable
Wireless
Make a wireless connection via a wireless LAN
WLAN Settings
Set the SSID of the access point. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Scan
Scan for a nearby access point.
Select this setting when you do not know the SSID of the access point. The system will detect nearby access points and display information on the SSID and security settings.
Enter Manually Specify the access point by entering its SSID manually using a keyboard.
Select this setting when you know the SSID.
Automatic U
Use the automatic setting feature of the access point.
This setting is available only in regions where PS3™ systems that support this feature are sold. Select this setting when using an access point that supports automatic setup. Follow the on-screen instructions.
WLAN Security Setting
Set an encryption key for an access point. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
None Do not set an encryption key.
WEP Set an encryption key.
The encryption key can be entered on the next screen. The encryption key is displayed as a series of asterisks.
WPA-PSK / WPA2-PSK
Authentication Setting
These settings are available only on PS3™ systems sold in Korea and are available only on PS3™ systems that are equipped with the wireless LAN feature.
None Do not set authentication information.
EAP-MD5 Set authentication information when using public WLAN services.
Enter your user ID and password on the next screen. For details, refer to the information supplied by the public WLAN service provider.
Ethernet Operation Mode
Set the Ethernet data transfer rate and operation method. Usually select [Auto-Detect].
Auto-Detect Automatically set basic settings.
Manual Settings Manually adjust the Ethernet data transfer rate and operation method.
IP Address Setting
Set the method for obtaining an IP address when connecting to the Internet.
Automatic Use the IP address allocated by the DHCP server.
You can enter the DHCP server host name on the next screen.
Manual Set the IP address manually.
You can enter values for the IP address, subnet mask, default router and primary and secondary DNS on the next screen.
PPPoE Connect to the Internet using PPPoE.
You can enter your user ID and password on the next screen.
DNS Setting
Set the DNS server.
Automatic Automatically acquire the DNS server address.
Manual Manually enter the DNS server address.
MTU
Configure the MTU value used when transmitting data. Usually select [Automatic].
Automatic Automatically set the MTU value.
Manual Specify the maximum size of data packets (in bytes) that can be sent in one transmission.
Proxy Server
Set the proxy server to be used.
Do Not Use Do not use a proxy server.
Use Use a proxy server.
You can enter the proxy server address and port number on the next screen.
UPnP
Set to enable or disable UPnP (Universal Plug and Play).
Enable Enable UPnP.
Disable Disable UPnP.
Posted on Sep 16, 2009
SOURCE: I followed your advice regarding Netgear not
how to install netgear switch
Posted on Dec 08, 2009
NetGear Gateway Access Problem
No to warner's locking the modem. 192.168.0.1 is the correct address for accessing the options within the modem. incidentally the Motorola wireless modem works better. Go on line to Netgear technical service and they will guide you through the task of setting up the system.
Feb 27, 2014 | NetGear WG602 802.11g/b Wireless Access...
I have 2 Westell modem/routers, one is a 7500 and the other is a 7550. I also have 2 netgear modem/routers WPN824, but currently using the 7500 for internet access. I am looking to extend my wireless...
its not to hard if you have a physical ethernet cord from point A to point B
Modem/Router ---ethernet cable--> 2nd router with dhcp off
as a bonus if you use the EXACT same SSID and password your wireless device will rome with no downtime switching networks
(oh.. very important to make certain they don't have the same IP. if main 1 is 192.168.1.1 then set the second to 192.168.1.2)
ta-da twice the network but all your devices think its all one
Sep 05, 2013 | Computers & Internet
Westell 6100g has one dataport, but I want to link to my Netgear WPN824 wireless router. XP machine.
Connect the NetGear WAN/ Internet port to the WAN/Internet port of the Westell cable modem, then connect your PC to any of the ports on the router
Then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Dec 30, 2010 | NetGear RangeMax WPN824 Wireless Router...
My pc has locked me out of the internet and i unfortunately didnt save the WEP key, the router is a NetgearWGT624 v3
The WEP encryption key is stored in the wireless setting in the Netgear wireless router.
Connect a LAN cable from the computer to the Netgear router and open IE browser and enter the Netgear configuration IP address (http://192.168.0.1) default login = admin default PW = password (type in the login password if you had changed it).
In the wireless encryption setting note down the encryption key. Use this key to configure the wireless card in the computer.
If you forgotten the PW then you can reset the router back to the factory configuration by using a sharp point and pressing the reset button at the back of the router until the LEDs flash, then release the Reset button.
Then login as previously stated. You can then create a new encryption key. I suggest you use WPA2 or WPA encryption key because it is much stronger than WEP.
I also suggest :-
Change the default password
Change the default SSID
For additional wireless security - enable MAC address filtering (this allows only listed MAC addresses of wireless cards to connect to this router - add the MAC address of your wireless card to the MAC address table in the wireless router).
Don't forget to configure the wireless card in the computer with the router's SSID and encryption key.
Oct 25, 2009 | NetGear WGT624 Wireless Router
Piggybacking a linksys wrt160n with a westell 327w
Did you put the correct WEP key in the router you are trying to add?
Sep 09, 2009 | Westell Wirespeed VersaLink...
Can i use my 2700gh-b dsl 2wire wireless modem as wireless router to time warner cable? If so, how? I'm a newbee. Please help! Thanks in advance.
This Router designed for DSL internet. It wont work for cable internet. Best thing is to trade in with a normal access point or wireless network router. Like Linksys, Belkin, Netgear etc
Jun 26, 2009 | 2wire 2700HG-B Router (2700HGB)
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
If you are connecting the Westell to the Netgear router, you need an ethernet connection(a different cable---AN ETHERNET CABLE)
Feb 21, 2009 | Linksys Wireless-G WRT54G Router
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Problem accessing router
You can try the link below and see if you can get the default password..
http://www.routerpasswords.com/
Jan 04, 2008 | Westell Wirespeed VersaLink...
Computers & Internet Logo
49 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
