Question about Kirsch Angle iron bracket 1" x 1"
We have standard type curtain rods that were used in installing drapes (installed about 25 years ago by professional installers). Instead of using the standard bracket with a slot, they used a bracket with about a 2 to 2 1/2 inch deep and about 1/2 inch high flange (extension?) that was actually inserted into the rod. The extension started out straight but curved a little and then straightened out. Presumably this way it fit tightly into the rod. One of these has now brokent, and we have not been able to find any brackets like this in a store or online. Are you familiar with anything like this?
  • maryemckay Oct 11, 2013
    I just found the bracket on blindsusa.com. It is a basic Kirsch bracket. They seem to have by far the most complete listing of brackets that I have found so far online.
I need the diameter of a curtain rod which has a 2" circumference. I am making drapes with grommets.
Circonference divided by 3,1416 = diameter.
C = Pi x D
.6637 inches
A bit more then 5/8 inches
Aug 22, 2017 | The Computers & Internet
How to install a tension shower curtain rod
Twist the rod to lengthen it. It has to have tension on it to hold it in place.
Oct 30, 2016 | Cars & Trucks
How to remove and replace ignition
you are going to have service manual like the dealer have, because its going to have all the special tools you are going to need to remove and install, plus all the diagrams, how everything is put together and when you are install the new part you dont end up with a few extra screws and when you go to use it and it does not work properly. is the ignition switch on the dash board or is on the stirring column, if its on the dash board it is held by screw and big nut on the inside panel, under the dash.
if you are doing a stirring column you need the proper tools, know where the release so the stirring wheel unlock, than remove the covers, than the ignition that the key goes into.
it been a few years since i had to do that type of work, about 20 yrs ago. and i figure it is lot harder to change it 20 yrs ago to day standards.
good luck rod
Mar 04, 2015 | Cars & Trucks
Crusher control rod and bracket
I wouldn't replace this unless you're a repairman. This isn't a circuit which can cost you. You should call the Maytag repairman? Is your warranty still in tact? I buy 5 year service plans as I used to sell and install appliances for Sears. A circuit board can cost you 4 times the service plan.
Sep 09, 2014 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Leaking roof
You need to call a roofer to install some metal flashing pieces. That will create a metal channel for the water to flow down instead of through your roof. Look in the Yellow Pages of your local phone book.
Dec 30, 2013 | Computers & Internet
I PUT UP A CURVED CURTAIN ROD. IT KEEP CUMMING OFF THE WALL
These rods need a little more support than a standard rod because of their shape. I'm assuming you used a plastic wall anchor in the gyproc or plaster. If so get rid of it and use a butterfly style anchor. The butterfly provides superior support and will allow to tighten the screws more tightly than with the plastic wall anchor. Good luck with your project and let me know if I can be of any further help.
Jul 30, 2010 | Rocky Mountain Hardware Shower Curtain Rod...
Adjustable (tension) shower curtain rod too long
Yes you can ! You only have to pull off the rubber end cap and cut it , file off ant burrs. Cut the SMALLER diameter end only, the other end contains the spring !
Nov 16, 2009 | Rocky Mountain Hardware Shower Curtain Rod...
How do i install an arc shower curtain rod
you cant you need studs.get the spring loaded rod.
Apr 04, 2009 | Home
Broken connecting rod
i broke the rod in my air compressor and cant find a place to buy a new one it is a pro source
Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Aug 27, 2008 | Moen Sienna Towel Bars Black Bathroom...
Kirsch Angle iron bracket 1" x 1" Logo
57 people viewed this question
Top Kirsch Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Kirsch Tool and Hardware - Other Expert? Answer questions, earn points and help others
