Question about Dometic RM2652 Refrigerator
Domestic Dm2652 will not work on AC without DC power is this correct. We have been camping for a week plugged into 30amp power. Refrigerator worked fine then check light came on and refrigerator stopped working. Check light stayed on AC and check light also stayed on under Gas mode but refrigerator not working. Pulled fuses nothing, changed gas bottles came on with full tank, now doing the same thing refrigerator out check battery put charger on battery. Now working but is there a internal problem or just battery problem
    Scholar:
  • 50 Answers
This is an RV frig correct? It SHOULD work either/or. AC or DC. If your plugged into AC then often the frig will work with that alone. DC is for when you have no AC so you can power your appliances of the battery. Maybe you have a converter (AC to DC which most RV's do) that somehow is not getting the DC to the frig.
Posted on Oct 12, 2013
  • 532 Answers
SOURCE: RV refrigerator works fine on AC power. Burns for 30 seconds on gas power then shuts off.
tap on the gas valve with a wrench,not too hard but not too light about 10 times,the valve is probably sticky from not being used,re-light and see what happens.
Posted on May 10, 2009
  • 155 Answers
SOURCE: The refrigerator works fine on electric, and on
turn of you power to refrigerator this will allow this will allow gas circuit to take over
Posted on Jun 22, 2010
SOURCE: Dometic RM3862 RV Refrigerator
This happens when your electrode fails. Replace your electrode.
Posted on Aug 17, 2010
SOURCE: I had to replace the WFCO power converter, as it
RVIA
Recreatio Vehicle Industry Assocition
http://www.rvpartwholesaler.com
Dometic 9108677537 A&E Carefree RV Awning Pull Strap
Dometic 3307834.006 A&E Carefree Window Awning Pull Strap 28"
WFCO 8955 55 amp converter. New w/ warranty! US Seller.
WFCO 9855 55 amp deck mount converter. New w/ warranty!
Posted on Mar 12, 2011
SOURCE: Dometic Americana RM2852 refrigerator does
Have the same unit but experience no problems. Sounds like a freon leak has left it inert. You can of course switch from auto to gas and eliminate the auto switch over as part of the problem. You can see the gas flame in the outside access hatch, (or maybe hear it) to be sure it is getting gas. since it doesn't respond in auto, which would also work in electric mode, I think it is the freon problem.
Posted on May 11, 2011
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Is it powered thru batteries or 110 volts
If it is a domestic brand dryer, it will run on mains ac power. If it was purchased at a solar or camping store, then it may use 12 or 24 volt dc power, if the latter is the case, it would be clearly marked and the power cord would not fit domestic home sockets, unless it was a second hand machine and had been amateurly modified in which case I would seek an experts inspection.
Sep 30, 2014 | Dryers
Help!!!
check power at camp ground if too low will not work either ac or LP board works off of 12 volts
Jun 24, 2013 | Dometic RM2652 Refrigerator
Dm2652
if Lp system is ok replace board but check gas line for obstructions if no clicking noise bad board or ignitor
May 30, 2013 | Dometic DM2652 Americana Fridge...
The power on my banshee is coming on?
Check the polarity of the adapter, if it isn't the original one. Even if you have the right voltage, it still has to have the mA or higher but, most important is the polarity. Most guitar pedals are wired backward on the plug. The positive is on the outside ring of the plug and negative is in the middle. There should be a picture or diagram somewhere on the unit close to the plug to find out. If it is backwards, it could have damaged it, maybe not though. If it is ok, cut the plug off and switch the wires and check it. After all, it's not working now, it couldn't hurt.
Mar 15, 2013 | Rocktron Banshee Guitar Talk Box Talkbox...
My dm2652 turns on but doesn't cool
Check the thermostat setting and check you have power from it to the heater if it is an absorption fridge or compressor if not.
Apr 21, 2012 | Dometic RM2652 Refrigerator
We have an Surveyor house trailer 3 years old, lightly used. The last time we tried to use the fridge it didn't work. Mod#DM2652 Ser#81708076. Checked the outlet that it is plugged into, it works,...
Since your unit is an AC and Gas unit, you need to find out if it works on gas in order to make a good diagnosis.
But from your description, it sounds like your DC power is not at the unit.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Jul 12, 2011 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
227 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
