Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Double images--3d view--ghost picture Sony KP-53HS30
How do I locate the convergence ics? where they are located in Sony KP-53HS30? How difficult it is to replace them? where can I buy them? where do I find the circuit diagram for the boards?
  • sonitv Sep 26, 2007
    Thanks for the prompt response.
    Genius:
  • 1,153 Answers
The convergence amps are the big STK's*** located possibly on the G-board in the sony. It is very difficult if you are not familiar with components and soldering, You can buy them at MCMelectronics, bluestar-online.com, Tritronics, VanceBaldwin.com, etc. Diagrams are online at fixya.com on the rightside of screen. Places like Manual.com or you can search the web. Hope this helps!
Posted on Sep 24, 2007
SOURCE:
Sony KP 51 HW 40 - in left half of screen picture has double images, right half of screen picture is normal.
This problems very common on DLP Tvs.This problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board is dead.Require to be replaced on the tv convergence board 2 STK convergence ICS and some or all it resistors to solved the tv convergence board problems,to solved tv convergence picture problems.The shop,will cost about $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-51HW40 51" Rear Projection...
Kp-53HS30, red blue green are not focused, seems like a 3D images..pictures is bright clear with slight curves verticly, turn on great..is this a convergence problem? are ther chips that can be replaced?...
Its nice to save money but unless you know what you are doing and have the right soldering equipment its best to leave this to a pro. you can open your tv and inside there are two large ics labeled STK 392-xxx those are where the problem is , however with sony tvs there are fuses that need to be replaced and possibly some resistors,. have a tv shop repair your tv. Julio - Millenium TV in Las Vegas
Dec 30, 2009 | Sony KP-53HS30 53" Rear Projection...
My sony projection tv has bouble image. can i
Well repair of TV depends on your own skills and if you have any experience of electronics stuff repair then it would not be difficult. This kind of repair requires good parts soldering in PCB expertise.
Your Sony KP-51HW40 seems have problem with convergence out ICs (two ICs) that would be replaced. Both ICs STK392-560 are located on D Board and available in Part Store.
Thanks.
Aug 21, 2009 | Sony Televison & Video
Double image ( Ghost image )on Sony KP-65WS500
Replacing the Convergence ICs should fix the problem. They are located on the Deflection board. Sony has used a couple of different ones over the years I think they are STK-392-120's but please do not hold me to it.
Hope this helps,
Skyassoc
Jun 25, 2009 | Sony KP-65WS500 65" Rear Projection...
I have problems with my convergence, the picture shows on a oval shape. Its a Sony KP-53HS30
You need to replace two convergence out ICs STK392-560 in D board of TV.
Above said ICs are available in Parts Store.
Apr 21, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony kp-53hs30 rear projection TV
replace the two convergence ICs and a couple 3.5 amp pico fuses. You need STK 392-560 convergence ICs. You can get replacment ICs and pico fuses at the following link. with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Aug 15, 2008 | Sony KP-53HS30 53" Rear Projection...
Distorted picture
dont touch those lenses that is not your problem the problem is your convergance ic are bad replace them and the fuses and this will fix your problem
Sep 15, 2007 | Sony KP-53HS30 53" Rear Projection...
DOUBLE IMAGES
How do we adjust convergence? I went to the service menu and all I see is alot of settings none of which help me out.
Can anyone explain this in further detail?
TIA
Aug 26, 2007 | Sony KP-53HS30 53" Rear Projection...
Red ghosts
red convergence went haywire... you need to relace I'm thinking two convergence ICs mounted on heatsink on convergence panel. replace both for usually they both blow replace any burnt resitors too, and hardest of all now you need to reconverge the whole thing.....which is a fine art.....u might be able to do it with the remote ...but u need a manual to go throught the steps really ..but not me i do em in my sleep. take it to shop unless your technical.
Aug 17, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
304 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
