Question about Whirlpool GR448LXPQ Electric Kitchen Range
Can you just replace the start button or do you have to replace the entire control panel on a Whirlpool Electric Kitchen range Model RF114PXSB????
  • Official Brand Answer
  • 407 Answers
Hi, there. While we cannot assist with repairs I can offer links to our troubleshooting, use and care guides, replacment parts, parts lists, and service line should that be necessary. We hope this helps.
http://bit.ly/zkfnZd
http://bit.ly/112Lu7q
http://bit.ly/LrNZiS
http://bit.ly/yLv4Z5
Posted on Oct 14, 2013
4 Suggested Answers
  • 41 Answers
SOURCE: Start Button Failed on Whirlpool Electric Range Model GY396LXPQ02
It sounds like you have an oven problem rather than a start button problem. Is there an error code? If so list your model and error code on a search engine and you will find error codes. Or you can just list make model number and error codes and you can find a chart of Whirlpool error codes. I have done this with no problem. That should tell you the exact problem and things to try.
It may be neither issue you mentioned. It could be a bad element or a short.
Posted on Aug 28, 2009
  • 132 Answers
SOURCE: Oven control issue on "YGY396LXPS01" Whirlpool electric range
Most likely you just need the main control board, and not the touch pad with the ribbon that goes to the board. Because the technician could not tell for sure he or she did not want to hang themselves installing a part when both are needed. The only sure way is to replace a part and see if it works usually changing the board fixes the problem, rarely are both needed.
this was dated about two weeks ago, hope it is fixed
Posted on Jan 15, 2010
Daniel S
  • 4323 Answers
SOURCE: Have a Whirlpool 30" free standing electric range.
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad again. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...
Daniel
Posted on Jan 14, 2011
Whirlpool Range #RF114PXSB , both bake and broiler elements won't go on
If the burners have the same problem check your power, it sounds like one of the phases is out. There is a common wire to both units, it is aparently open.
Aug 24, 2014 | Whirlpool RF114PXSB 30-in Electric Range
How to calibrate a digital whirlpool oven model RF114pxsb 3
There is no way to calibrate the oven temp. You need to replace the temp probe in the over. Here is that part to order.
There is also a video on that parts page to show you how to make the repair.
Oct 25, 2013 | Whirlpool Kitchen Ranges
Whirlpool oven range panel says loc?
This is the control panel lock. Press and hold Start for ~5 seconds until the tone sounds to toggle the lock off. This will only work to toggle off the lock if the Timer and the Timed Cook function are not in use.
When the Lock is active, you can use the Clock, Timer Set and Timer off buttons. Manuals are available for Whirlpool GY396 ranges here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?form_state=literatureSearch&context=&siteCd=WHRCOM&form_state=literatureSearch&searchTerm=GY396 . If this link doesn't work, start here: http://www.whirlpool.com/custserv/index.jsp and enter your model in the Manuals and Literature search area.
I hope this helps.
Mar 12, 2011 | Whirlpool GY396 Electric Kitchen Range
Dec 30, 2009 | Whirlpool GY396 Electric Kitchen Range
May 29, 2009 | Whirlpool GY396 Electric Kitchen Range
Whirlpool Gold electric range control panel not working
I live in a new 500 home subdivision. The contractor ordered all Whirlpool Gold products including Electric and Electric/Gas Ranges. Many of my neighbors' panels have gone out! I'm talking about epedemic trouble. My son has had his oven panel (separate from stovetop) fail within the first year. Thank God it was under warranty...this is not a cheap replacement (he had the sensor touch pad. I just had my oven pad fail. I tried to set the clock for Daylight Savings and found out half my panel is out! The fix is a replacement of the panel. Depending on which model (push or sensor) look to spend at least a couple of hundred bucks. We have the Whirlpool Gold microwave panel and so far so good. My neighbor and my son's both went out! They just tossed the two year old products and replaced them with another brand. Sorry to break you the news...class action anyone?
Mar 04, 2009 | Whirlpool GY396 Electric Kitchen Range
KitchenAid KESH307HBL4 Electric smooth top
that a tough one, when you press the start do you here a tione indicating that you depressed it??? if so then i would say your getting the power from the switch, and the burnt relay is the issue, but if theres no audio indication of hitting the button id replace both
Oct 25, 2008 | KitchenAid KESC307 Electric Kitchen Range
Whirlpool GR448LXPQ Electric Kitchen Range Logo
79 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
