My Back-UPS 500 Surge Protection & Power Back-up (model BK500M) once in a blue moon beeps (once every 4 months) then my PC shuts off immediately. Is this normal? However it looks like there was no power cut as other electrical appliances were not reacting at the time of the shut off.
  • Ice Nine Oct 08, 2015
    Hi, I have a APC UPS and occasionally it goes into a beep mode. First; Open the case, on mine it is the removal of one Philips screw to slid the battery cover off, then check the battery voltage. These batteries do not last forever. Mine was showing 13.8 volts so I knew it wasn't the battery. I unplugged the unit from the wall outlet, pushed the reset button and then plugged the unit back into the wall outlet. This seems to reset the UPS and everything was fine again.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
It is performing a automatic self test. If fails this test. That is why your PC turns of
Posted on Oct 24, 2013
tech240
  • 169 Answers
SOURCE: Belkin UPS F6C800 Problem
Just a general point. any ups is designed to deliver power inside its design parameters. any load outside its design parameters will cause it to shutdown or in the case of more expensive models it will go to bypass, some models will then recover and go back to inverter.
eg stable overload
peak overload
load outside its normal crest factor
short circuit
Posted on Apr 23, 2008
SOURCE: Mge nova avr 1250 problem
ups charged for 8 hrs .No alarms but on powerfail no output to connected device
Posted on Jun 20, 2009
  • 1684 Answers
SOURCE: APC UPS 1500 w/full load forces immediate reboot at pwr failure
With a 980watt load the run time is only 7 minutes on a brand new battery. If you have the system on full load your run time will be much less and it has likely damaged the battery. here is the APC web site page for your model. If you are running that much equipment I think you need either a bigger UPS or another 1500 and spread the load out.
Buddy
Corporate Computer
Posted on Jul 24, 2009
SOURCE: Microtek 600 Heritage+ is not giving back up after the power cut
the backup noice is contenu running
Posted on Mar 05, 2010
  • 84 Answers
SOURCE: I have an Ativa battery UPS surge protector model
I have found your user manual here: http://www.apcmedia.com/salestools/KBOK-76HP9K_R0_EN.pdf
It looks like a re-badged APC unit, so the problem is either the battery is dead (probaby likely no matter what) and unable to support the load, or an overload condition is detected.
it is also possible the unit has gone faulty, but without more information I can not be sure.
If the manual does not help or you are still not sure, give me some more information before rating and I will continue to try to help.
Posted on Apr 12, 2010
How to disable timer in APC ES 500 UPS
Hi Cris,
What do you mean by timer? If you are referring to a beeping sound coming from the unit it means that it has a low battery and to replace immediately.
If you need pricing for the battery let me know, we have very competitive pricing available for all makes and model UPS systems.
If you need UPS, Surge, or Power Related help contact Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/ ** If this helped - click YES :) **
Mar 10, 2014 | Computers & Internet
APC UPS ES 500 series continuous beep sound and flashing green light
Hi Lasantha,
Check the battery in your UPS - it's most likely going bad and you will need to replace it.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
** If this helped - Give it a Thumbs Up :) **
Dec 03, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Power supply malfunctioning
Most surge protection power boards will protect computer equipment from mains spikes and surges.
A better and more expensive solution is to use an uninterruptible power supply (UPS). These units provide surge and spike protection and also provide power in the event of mains power failure.
Make sure you select an UPS model that meet the power requirements of all your computer equipment that is connected to the UPS with a mains down time of say 1/2 hour to give you time to shut down your computer in an orderly manner.
Sep 09, 2012 | Dell OptiPlex 780 PC Desktop
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
How can I configure or why only one computer will not turn off after power failure? I use UPS model KE-600A with 4 outlet(output) but during powerfailed only one computer will used the UPS and the will...
I am not sure on the outlets on the back of this unit.
It is likely that the outlets on the back of the (UPS) are labeled, some battery backup (UPS) and the rest are surge protection only (no UPS).
Of the 3 UPS units I have, on each unit, only about half of the outlets give UPS protection.
The rest are surge protection.
Let me know it this helps you.
Post your questions as a comment or reply and I'll be notified.
Feb 05, 2011 | Computers & Internet
Need information
The Back-UPS is fairly straight-forward. The 9-pin connector (at the top of the back) is a serial port (RS-232) for the UPS data (when connected to a computer it will shut down the computer safely during a power outage). The next plugs are RJ-11 telephone jacks; the cord from the jack (wall) goes in on the left (some models have RJ-45 for network protection). The battery protected outlets are the three surrounded by black paint. The other three provide surge-protection only. Do not plug items like printers and scanners into the outlets that provide battery protection.
I hope this helps.
(for software, manuals and other information:
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BP650S&tab=models )
Apr 17, 2010 | APC Back-UPS Pro 650 UPS System
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
House power fluctuates, UPS and computer die.
Sounds like the internal battery of the UPS needs replacement. Contact APC and ask for a qoute for a replacement battery/service. It'll probably work out a cheaper to buy new.
Make sure you dispose of the old unit properly if you do replace
Jul 07, 2009 | APC Back-UPS CS 500VA UPS System
Beeping noise
I've had the Dell 1720dn at my desk for years. Worked flawlessly. Moved it to a different workstation and it began beeping immediately while printing. Another site said to plug it directly into the wall, instead of a battery backup. I unplugged it from the battery backup outlet, and plugged into a surge protector only outlet on the same battery backup unit.... NO MORE BEEPING. Hope this helps someone else.
Apr 01, 2008 | Dell 1720dn Laser Printer
APC UPS no power
The unit might have a dead battery, blow fuse, or a bad board.
Your best bet is to talk to an APC rep. Worst case, APC has a trade in program, and can give you a discount on a new one.
Good luck.
Try Chatting with an APC Support agent online.
Here is their direct link:
http://www.apc.com/support/chat.cfm
Chat with a Support Agent
Chat with Support for immediate assistance with your APC Back-UPS, Cable, Surge Protection, Notebook and Mobile Device accessories and products. Agents are available Monday through Friday from 8:00 a.m. to 8:00 p.m.
Feb 07, 2008 | Computers & Internet
Computers & Internet Logo
252 people viewed this question
David Payne
David Payne
