Question about Karcher 2500 PSI Pressure Washer
MY 1997 OLDS KEEP LEAKING ANTIFREEZE AND IT NOT FROM THE RADIATOR. COULD IT BE THE FREEZE PLUG?
  • 7,482 Answers
Hi Jean
Yes it could be a freeze plug but also may be a gasket or hose that is leaking.
Get the car to a dry hard surface and let it run, then check to see if you can locate the leak...you may have to put it on jack stands to accomplish looking under the vehicle...just make sure it is not running at the time you go under the vehicle
Bud
Posted on Oct 11, 2013
I have a 1990 Mitsubishi Might Max truck It is leaking antifreeze but I can't find a leak What do you suggest
Check around radiator,hoses,heater hose,freeze plugs,and radiator drain plug.thermostalt housing,head gasket,radiator cap and over flow bottle.
Apr 07, 2014 | Cars & Trucks
Engine light blinking and anti freeze every where
The engine light is probably telling you the engine is heating up. It can be a simple broken hose, water pump, or radiator problem. Sometimes it is in the heater core hoses too.
There are some tests that can be done with a tool called a Radiator pressure tester. You may be able to borrow one from the Tool Loaner programs at big autoparts stores like Autozone. If you add water it can freeze if all is not removed.
Water is your cheapest test substance, but you can use antifreeze if you catch and recover it. Using the test tools I suggested will quickly reveal the leak source.
Two final things. Limit the pressure in the system to 14 or so lbs and observe the FREEZE plugs for leaks on the sides of the engine.
A slow leak can be driven a short distance to a repair shop if you start with a full Radiator.
Please rate my info.
Jan 22, 2013 | 1997 Chevrolet Lumina
Antifreeze is leaking on the passenger side of the car behind the engine where could the leak be coing from
For this types of problem,check the help link provided below.Click the link below to go through its troubleshooting procedure:-----Antifreeze leaking from front of engine near Air intake? http://technoanswers.blogspot.in/2012/02/antifreeze-leaking-from-front-of-engine.html
----------Antifreeze leaking from freeze plug on throttle body? http://technoanswers.blogspot.in/2012/02/antifreeze-leaking-from-freeze-plug-on.html
---------How to locate the vacuum leak? http://howtobyme.blogspot.in/2012/01/how-to-locate-vacuum-leak.html
-----------How to Perform Car AC Leak detection Test? http://repairhelpcenter.blogspot.com/2011/11/how-to-perform-car-ac-leak-detection.html
------------Common Causes of Car Oil Leaks? http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html----------- Troubleshoot Car Oil leak? http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
-----------The plastic housing which goes to the upper radiator hose is cracked and leaking?
http://schematicsdiagram.blogspot.com/2011/12/plastic-housing-which-goes-to-upper.html
Radiator leaking? http://repairhelpcenter.blogspot.com/2011/12/radiator-leaking.html
-----------This will help.Thanks.
Feb 08, 2012 | 1997 Buick Century
How much work is it to fix a leak. it is spraying out anti freeze up by the motor. It looks like maybe the where the seal may go
If the leak is a hose, not a big deal. Drain antifreeze disconnect hose, instal new hose, refill antifreeze. If the leak is a water pump also not a big deal, same procedure.
If the leak is in the radiator, a bit more complicated. Radiator can be replaced or repaired by a radiator shop.
If leak is coming from somewhere else on the engine, could be more serious, like a gasket leak. If this happened you would get fluids mixing ( oil/gas)
Good luck. A Haynes manual is a good investment for your car.
Feb 05, 2010 | 1997 Oldsmobile Achieva
Py 1997 plynouth voyager is leaking antifreeze could it be freeze plugs and where are they
They are called CORE plugs as when they are made they take out all the sand out of the holes and fit in plugs.But if your leaking water out and cannot find it then yes its a core plug... as all summer you use coolant min 20%,Winter coming on 20% Antifreeze. and soon as winter is finished you should flush out the engine and radiator as Antifreeze causes the block to go rusty as its cast iron and the core plugs must be BRASS not steel because antifreeze eats away the plugs
But the plugs are fitted 1Rear of engine behind the flywheel 3 either side of engine block and some times 3 or 4 in the heads under the rocker gear..
Let me know how you get on .. Ron
Nov 11, 2009 | 1997 Plymouth Voyager
My antifreeze light came on so I pulled into a gas station and bought some universal antifreeze green in color now that I'm home my husband says I should have bought the red stuff. What is the proper color...
The Orange antifreeze called GM Dexi cool, (red to your husband LOL). It's ok you put the green antifreeze in. The difference is the Green antifreeze has a of 1 year or 30,000 miles and the Orange has a life expectancy of 5 years or 100,000 miles. Being your Lumina is 12 years old and if the Orange antifreeze has never been flushed out, most likely crystals have formed in the water jackets and passageways through out the cooling system. The crystals can be flushed out with Preston radiator flush, but will take a few flushes to ensure that most of the crystals are out. Once flushed out, replace the antifreeze with the GM Dexi cool 50/50 mix water/antifreeze. Too much water will freeze and can crack the engine block, radiator, or heater core. To much Antifreeze will gel up causing the coolant to flow slower and then the engine tends to over heat. Note, it's a good time to replace the thermostat and spend the extra money for the fail safe thermostat. Good luck and keep me posted, be glad to answer any more questions.
Nov 10, 2009 | 1997 Chevrolet Lumina
Coolant loss
From what you described I suspect you have a hole in a freeze plug. They tend to rust out over the years, especially if you’re running a high percentage water and a low percentage antifreeze for your coolant. Try to fill your radiator when the engine is cold. If you have a hole in a freeze plug you won't be able to keep the radiator full. The water will just keep running out the hole. If you can fill the radiator and don't see any leaks, it's probably not a freeze plug. It may be a sliced hose that will only leak when the engine is warm. If you do have a leak, try to look under the car and see where the water is coming from. Freeze plugs look like round shallow indentation in the engine block. They're usually about 1.5 inches in diameter. If you find a leaking freeze plug you can usually pop it out by driving a large screwdriver into the hole and then use the screw driver to pry the metal freeze plug out. Buy a new freeze plug of the same size at an auto parts store and tap it back into the circular opening. Do your best to clean the edges of the opening first. Put one end of a deep well socket that's slightly smaller than the freeze plug against the outer wall of the freeze plug and tap on the other end of the socket with a hammer to drive the plug into the opening in the engine block. This will help you to drive it in straight. If there's enough room to swing a hammer, freeze plugs usually aren't too difficult to replace. However, if there's no working room they can be very difficult to replace. If this is the case you may want to take it to a garage.
Jun 17, 2009 | 1997 Oldsmobile Achieva
Coolant leaking from two russted freze plugs on the side closest to the heater core
Having enough room to hit the new freeze plug to install it is probably your biggest problem They make an expandable freeze plug which tightens with a socket, but aside from a hot block, I don't know how close to the exhaust manifold your freeze plugs are. An emergency repair may be to drain the antifreeze, clean and scuff the old freezeplug and try JB Weld. If you have a small leak after that, some radiator sealer may finish the job.
May 02, 2009 | Oldsmobile Cutlass Ciera Cars & Trucks
Karcher 2500 PSI Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
